Vespa
Vespa
Hi all,
It's been some time since I had an old school Vespa, I just picked this up. It was on a display in a restaurant for years. They think it's a 67', I am having issues decoding it. Everything on it is super clean, no rust or rot, or bondo traps. It might be an Indonesian Vespa, I don't know much about that other than they exist and sometimes suck at renovations.
I found a lot of information on VBC Vespas without the "T" in the Vin, but still unclear on exactly how to see what it is
Two questions:
1) Help decoding!
Body: VBC1 (star) 318362
Engine: 319234 (star)
2) This key doesn't stay in position, it turns counterclockwise (toward the driver) and springs back, this is keyed for ignition or steering wheel lock? What do I do with this key switch to get it started?
Any help would be amazing. Thanks all.
[/img]
@gickspeed avatar
@gickspeed avatar
scooterduder wrote:
Hi all,
Two questions:
1) Help decoding!
[/img]
i see the column lock, but is there an ignition lock i'm not seeing? The column lock only serves one purpose, it prohibits the steering column from moving. There are no electrical connections that go to it.
What Mr. Gick said, you just kick that lever on the engine side down to start it and there's a button on the side of the right hand switch to shut the engine off.
@pheasant_plucker avatar
bare metal cafe racer
As you have discovered - the missing "T" seems to be common to Dan Motors Vespas (Indonesian). No one seems to know if all DM Vespas are missing the "T" or if there are other manufacturers who also didn't place a "T". The trap headset is also very DM.
Know that DM produced very good quality machines, and at times had options (like extra porting) that were ahead of their time. Problem is the Vespas they made tended to be used for their intended purpose daily since they were made - literally ridden into the ground. There are exceptions - but they are few and far between (like winning lotto chances).
Your frame returns as a 1975 150 Super on scooterhelp. I note the lack of frame detail on the tunnel next to the floor - should be able to see the seams on the tunnel near the leg shield and back of the tunnel mat. It strongly suggests a liberal amount of bondo.
As for the key - ain't no room to fit an electric ignition behind there (that I know of). Addition of keyed ignition generally ends up near the fuel tap. If the steering lock isn't engaging then it's better than if it was stuck on - think you would need to drop the fork and pull the lock to figure exactly what is going on.
Go over that bike with a fine toothed comb… I briefly had an Indo Sprint V that looked sweet from afar and to the untrained eye. Hiding plenty of disaster unfortunately. Live and learn (but gotta live…)
OMG! Look what I just scored - 1977 Sprint 150
Vespa
Vespa
Thanks! I'll definitely go through it more. I got the same, a 1975 Super 150, by typing in the Vin without the "T". Is there anymore info for vins with these Dan motors Indo Vespas? Or is it most likely a 75?
Not that I've found. And nothing official either - just lots of reports of Indo frames missing the "T".
Fair bit on Dan Motors history out there. But nothing specific really.
Don't even know if the missing "T" is from frames made by DM or those that came in as CKDs (complete knock downs). I think CKDs only made up a very small proportion of DM bikes, and only a few years (but don't quote me on that…) Brother E (Koenig Blues) and the Indo crew on here should know more.
[ Time: 0.0091s ][ Queries: 4 (0.0035s) ][ live ][ 313 ][ ThingOne ]
