GTS super 300
GTS super 300
Hello. I want to put heavier rollers and the only ones I found were Malossi 20x17 15gr. How do you think could affect the scooter? Thanks
GT 2.4
GT 2.4
It will slow you right down. Also, if you put in heavier weights, going up hills is going to be a ponderous experience. Are there hills in Costa Rica?
@guzzi_gal avatar
Gigi, '13 GTS 300ie Touring
@guzzi_gal avatar
As I understand it, lighter rollers equal faster acceleration from a standstill without any increase in top speed.
GTS super 300
GTS super 300
@mike_holland avatar
GTS300 Super 2015 Blue, GTS300 Super 2023 Beige
I use 12.5 gram rollers in my GTS300. Gives good performance without over-revving.
GTS super 300
GTS super 300
@waspmike avatar
@waspmike avatar
One really needs tachometer understand what is happening with a scooter rubber belt CVT.
Say the scooter revs to 5350 rpm during acceleration. Then we discover that at a steady speed of 40 mph the RPM is 5500, 45mph is 6400 rpm and 50 mph is 7200 RPM. This means at 5350 under acceleration the gear ratio is changing and the scooter's speed increases until the front or driven pulley has been squeezed together its maximum amount and the gear ratio is at its maximum. (top gear)
From 5350/5500 rpm upwards it is only increasing engine RPM which increases the scooter's speed, until either the engine either reaches maximum power or maximum RPM (rev limiter).
With a front pulley and weights of stock or standard dimensions the CVT itself can only influence the scooter's performance up to approx. 40 mph. Above 40 it is just engine power and the resulting RPM.
If we fit lighter weights the force required to change the ratios needs more RPM ( centrifugal force) so the scooter may rev to say 6400 during acceleration to generate the same force as before and the pulley halves are not squeezed together the maximum amount until approx 45mph. The maximum speed which the scooter reaches will be the same as before as a result of power or maximum RPM (rev limiter).
Fitting heavier weights will lower the RPM which is required to achieve maximum pulley squeezing at a lower speed. Meaning the scooter will be in top gear sooner and again relying only on engine power and RPM to influence top speed.
It is all a balancing act and no variator or weight manufacturers seem willing to share what RPM they aim for. Hence the need for a tach.
[ Time: 0.0129s ][ Queries: 3 (0.0045s) ][ live ][ 313 ][ ThingOne ]
