Rally 200
Rally 200
Hi folks
I'm in need of some advice please. I'm having an issue with my fuel tap leaking it's an original with the bowl at the bottom, I'm looking to fit a new one, what would you guys recommend?
Also do I need to change the lever for a longer one or will the original still work?
Thanks for any help
Cgt75b.
@mjrally avatar
@mjrally avatar
Ring up your local scooter shop and buy a new fuel tap and a fuel tap wrench for a Rally gas tank. New taps don't have the bowl, but will work with the existing lever.
If your fuel hose is rock hard, might consider buying a new one with some screw type hose clamps as well.
Rally 200
Rally 200
Hi folks
Just an update on this issue
I fitted an SIP FF fuel tap all seems to be working well now. I also had a leak from the carb to air box, so I bought some 1 mil gasket sheet from eBay and made up a gasket, happily with the desired result of a leak free carb.
Hope this maybe helps someone out in the future.
Thanks for your help MJ Rally.
Best regards
Cgt75b 😎
Cgt75b wrote:
Hi folks
Best regards
Cgt75b 😎
I bought a sip ff tap version 2.0 for my dr177 px, saved so much aggro from low petrol gravity tank fuel starvation issues, very good part. I tighten my carb to box up every couple of months as they do loosen over time.
[ Time: 0.0102s ][ Queries: 3 (0.0031s) ][ live ][ 313 ][ ThingOne ]
