@garncarz avatar
1964 Allstate Cruisaire, 2022 Husqvarna Vitpilen 401, 1972 Suzuki T500J
@garncarz avatar
Does anyone have a method of removing the fuel petcock from a VNB that doesn't include buying the $40 wrench for what is likely a one time use? Thanks.
@r_fostoria avatar
'66 Sears Cruisaire Smallframe
@r_fostoria avatar
I have one of those wrenches if you want to borrow it.
@garncarz avatar
@garncarz avatar
That would be great! When and where could I collect it?
⚠️ Last edited by garncarz on UTC; edited 1 time
@subetherbass avatar
Yip, borrowing one is the best way... i think most of the time noone actually knows who originally "owned" the tool, they're just always somewhere when you need it, then it disappears just as quickly when the next person needs it
It won't be a one time use as you'll have to use it to install the new tap. 😁
Rally 200
Rally 200
Deffo worth having the proper tool for the job.
@garncarz avatar
@garncarz avatar
Dug a rotten filter screen out and about an ounce of dirt. Flows great now. Thanks Steve.
I used one of these adjustable pipe wrenches. Worked fine for me.
@scooterraton avatar
2 - Many
2 - Many
GS 160 and SS 180 use a different wrench...of course
Old douglas ..smallie with polini 115..super with nasco 177
cut piece of exhaust pipe off a car wreck...flatten two sides with a hammer...and cut a small tee shaped slot using hacksaw up the side for the breather to rotate through(or pull breather pipe out) .....works mint.....try different diameter pipes
[ Time: 0.0111s ][ Queries: 4 (0.0023s) ][ live ][ 313 ][ ThingOne ]
