@popgunandy avatar
61 VBB 76 Rally 200 79 P200 80 Sport 100
@popgunandy avatar
I've never seen this happen before...one of my scooters suddenly started running like crap and when I opened the carb box I discovered one of the bolts had worked its way loose and created a massive air leak. It's weird because I've easily put 100 miles on her since the last time I touched the carb and all of it was trouble free.
Anyway, besides retightening the two bolts does anyone have two cents on this? I did pull the cylinder head and confirmed no damage there.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
Get all new hardware, I had some like that and even loctite wouldn't hold them
@popgunandy avatar
@popgunandy avatar
Including the studs?
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
There should be a spring washer on each bolt to keep it under tension when tightened down.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
I'd do studs too, you don't know what part is jacked. And yeah SoCal is right make sue you have the spring washer in there too
P200e
P200e
Just put it on with the correct washer, tighten it down, and ride.
It's nothing.
@ray8 avatar
@ray8 avatar
There should be a spring washer under that bolt.
It looks offhand like you torqued the right side bolt, then tightened down that left bolt. What happens with Spaco carbs especially is they will get deflected by that steel bolt. When you go to torque down the left bolt you're fighting that deflection, so it feels like it's tightened down when it isn't. Both bolts have to be torqued in unison, slowly.
I'm betting you're fine if you torque 'em correctly, with maybe a new silicone gasket.
@chandlerman avatar
Lucky
71 Days Since Last Explosion
Lucky
@chandlerman avatar
For the carb, I tighten then hand tight, then alternate 1/4 turns with the torque wrench until they both click. Ideally, they will click on the same turn.
@scooterist avatar
@scooterist avatar
I had a similar problem on my engine. At one point during the engine swap we put the wrong size engine case studs, not only made it run horrible but it also ran very hot and it would take 20-25 kicks just to start.
Another think that I found is that one of the carburetor 11mm hollow nut was cracked and therefore it wasn't tightening on the stud.
Your solution is to put brane new engine cases studs and brand new carburetor 11mm hollow nuts/bolts with the two sets of new washer each.
various, but less than I used to have
If the other bolt stayed tight, high probability your carb is warped now. Take it off and set it on a true flat metal surface.
@sea avatar
'61 Cushman GS150, '62 GS160, '74 Rally 200
@sea avatar
I would only tighten anything related to the carb by hand, and never over tighten. Just tighten the screws until they are snug (and alternate, as suggested). I would not use a torque wrench. These scooters were designed for people to maintain (mostly) on their own, and do roadside repairs. It's really not that scientific.
Regarding your post question, you need to periodically go around your whole scooter and check all the bolts and screws, and tighten as needed (carb, wheels, steering column, etc.). Over time, these will all loosen to a degree.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
for the carb bolts I recommend a torque wrench, it is EASY to overdo them
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
I 100% agree with this.
The whole point of torque wrenches and torque specs is to ensure the right amount (neither too much nor too little) of tightening.
[ Time: 0.0131s ][ Queries: 4 (0.0029s) ][ live ][ 313 ][ ThingOne ]
