@feruza avatar
Motovespa 150 GS (1967)
@feruza avatar
Hi!
Can anyone tell from just this photo if I've got a Stoffi spring installed?
@gickspeed avatar
@gickspeed avatar
feruza wrote:
Hi!
Maybe. Looks like it, but not 💯 %. It's too rigid. Replace with SIP uprated spring.
@feruza avatar
@feruza avatar
I'm about to finally get the SIP shock and for all I've read the Stoffi seems to be too stiff.
Could I also change the spring at a later stage?
@gickspeed avatar
@gickspeed avatar
sure, you could change later. . . .but that spring is too stiff. pay the $46.10 for a spring that will be much more pleasant.
@feruza avatar
@feruza avatar
In the process of changing my spring as you recommend before the shock.
@stuarttiainen avatar
PX232, Super221, Rat PX200, Rally 221MHR
I replaced my standard setup on my VNA with stoffi spring and BGM damper, worked superb, didn't dive under braking anymore.
@feruza avatar
@feruza avatar
That's my current setup and works quite well when it comes to diving. However, I find it too hard and unpleasant when hitting potholes, bumps or riding on uneven surfaces…
I want to go for something softer.
⚠️ Last edited by feruza on UTC; edited 2 times
@feruza avatar
@feruza avatar
Do you ride your BGM on its hardest setting?
No, never found it unpleasant. Can't remember what setting I had it on, I haven't had this scooter for over 1 yr now... Have you had a play around with the BGM damper to see what setting is best for you?
@feruza avatar
@feruza avatar
I have but not much difference. Here is a photo so you can see how compressed it is.
[ Time: 0.0148s ][ Queries: 4 (0.0039s) ][ live ][ 313 ][ ThingOne ]
