VNB VSC VMA VSX - o9c vbc vmb
7 or 8 scoots that I can think of... and they all either had no drip tray, the drip tray was broken, or I broke the damn drip tray trying to remove it...
Yesterday the clouds parted and angels sang (choral version of Bring it on Home by Sam Cooke ICUWW) as I successfully removed a drip tray from the white P.
It's the small things sometimes.
Carry on...
A plastic miracle.
A plastic miracle.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Ha, yep know the feeling. But don't celebrate too soon ... you still need to put it back in.
Ancient drip tray repair attempt = utter failure
SoCalGuy wrote:
...don't celebrate too soon ... you still need to put it back in.
LOLZ!
Damn it!
*kicks dirt*
@chandlerman avatar
Lucky
69 Days Since Last Explosion
Lucky
@chandlerman avatar
Or he could just mount it on a plaque and hang it on the wall.
@fatbear5 avatar
1977 P200, 1980 P200
@fatbear5 avatar
Yes, getting it out is easy (relatively) it's putting it back that's a bitch... especially if you've run any extra wires or cables through the tunnel. My drip tray is in a box marked Future Projects... I expect it will be there for a long time.
I broke 2 or 3 before I started heating them up first with a heat gun set on low. Since then, no problems.
@qascooter avatar
@qascooter avatar
Thanks for this Top Tip - I'll be using it shortly!
parallelogramerist
parallelogramerist
I usually lube up the drip tray with blood from my knuckles, then it slips right back into place.
@pigletpilot avatar
@pigletpilot avatar
ROFL emoticon
PX150E
PX150E
The drip tray is actually useless; If there is a leak, oil or gas, it's going to flow down on the floor board anyway.
Usually, there is some 2T oil on it from the oil tank tap or upper coupling collar. So, over the past several years, whenever the tank comes off for a fuel line replacement, I stuff a folded absorbent pad at the bottom of the tunnel, under the drip tray.
Every time I do this, the pad is soaked.
..add some tears of frustration and it'll be like butter getting it back in.
It is amazing that these can still be found original and not cracked or broken. I have three original ones held together with epoxy. The one I have that is nos and unbroken has never been installed. I think that's why it's not broken yet.
@beaconhillfox avatar
Vespa PX 125 (177 Pinasco) 1967 Sprint 150 (PX200cc)
Do replace it/fit the tray back in. On some Vespa large frames, if it is missing, it will do something weird to the air intake, it's more than just a drip tray/wire access cover- I think extra air gets in the frame cavity as you go along at speed and there's too much air/pressure, if that makes sense. The carb gets its air from inside the fame cavity via the rubber bellows. On my PX 177cc, I always got an annoying flat spot when dropping off the throttle in 4th then throttling up. Took me years to figure it out, it was some posts on these forums that mentioned it as a possibility. Some folks says its nonsense, and I guess it may only effect a few Vespas but on both my PX and older Sprint the trays were missing. Both had the flat spot issue (but not so bad on the older Sprint which has a PX200 engine), both fixed now. The one I ordered for the Sprint was a sod to fit, but with a bit of sanding and grease down the edges it went in, eventually.
https://modernvespa.com/forum/post938890#938890
Cheers
Mark
@67gt125 avatar
1967 Granturismo 177, 1979 P200E, 1974 Primavera 125 Hooligans S/C Seattle/Austin
@67gt125 avatar
I ought to scan one and pump a bunch out.
Little did my boss know, I'd be using this thing solely for "business" ROFL emoticon
@oopsclunkthud avatar
3:5
the original ones fit well and tend not to crack (in my experience) but the new replacements suck.
Be sure not to clean up the blood, just make it an offering
@kimono32 avatar
'66 Super 150
@kimono32 avatar
'66 Super 150
Congrats on your success, Birdsnest!! It succked bigtime, yes?
I have met the enemy and his/her name is Stupid Plastic Drip-Tray
Had no idea it was also ridiculously difficult for the experienced.... thot it was just me.
My takeaways: Squish SIDEWAYS, not front/back to remove. Swear as LOUD as humanly possible to re-fit (even if you're a lady most times) and hope your neighbors don't think you're beating your children in the garage..... That's all I got
(Yeah, yeah, blood, sweat, tears, knuckle skin, fingernails, etc. Worst job ever. Except circlip on choke....Congrats again!)
@kimono32 avatar
'66 Super 150
@kimono32 avatar
'66 Super 150
Whut gloves...?
@67gt125 avatar
@67gt125 avatar
I don't know why reaching into the tunnel is like wrestling a crocodile. Your glove looks better than mine last time I had to run cables out back. My P had a light oil tank leak. So there was also a heavy layer of nasty gunk in there
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
Duh. I mean, the dripping blood is what the trays are there to catch, after all!
@safis avatar
@safis avatar
I always get the original (Piaggio) since it's cheap (I get them for 5€) and of the best quality. It was redesigned so it fits old and new frames. Loom "pocket" has moved to the back so installation it's much cleaner and throttle cable doesn't interfere…
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
I didn't know it needed one Laughing emoticon
Add that to the next shopping list...
PX150E
PX150E
I don't understand what this fuss is all about. I removed and replaced my original one many times, and it is very easy to do so. Working it around the cables and cowl latches to get it into position has never been a problem, since it is quite flexible
And, a couple of times, I have forgotten to put back in while reinstalling the tank/oil tank assembly, and the motor has continued to perform exactly the same throughout the rev range.
What am I missing here?
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
On older scoots the tray is usually brittle, warped and/or fused in place from years of gas gunk and grime, making it hard to remove. And the new trays sold by most shops tend to be generic "one size fits all" for P Series and Stellas and don't quite fit earlier models.
But...it is designated as a Grade A first class repair.
[ Time: 0.0124s ][ Queries: 4 (0.0055s) ][ live ][ 313 ][ ThingOne ]
