Vespa 90
Vespa 90
Hi,
I'm new to here as need help dating a Vespa I have bought. Also it has never been registered for road use could anybody advise what I need to do to register it.
VIN Number
VIN Number
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
Moved to Not-So-Modern
@gickspeed avatar
@gickspeed avatar
Clivet wrote:
Hi,
very user friendly: https://www.scooterhelp.com/serial/ves.frame.serial.numbers.html
1965.
@neil_edgar avatar
'81 50 special,'57 GS150 VS3,'59 152L2,'60 SII Li150
@neil_edgar avatar
Hello,
Frame number is nice and clear, hopefully the engine number is also in good order. I'm assuming you are Kent in the UK? The first step is to apply for a dating certificate. The Veteran Vespa Club can do this. That will give date and model details. To register the restored scooter will then need and MOT, and maybe DVLA inspection. The main problem, is if the scooter is an import. Then the registration process seems to be coming harder by the day, depending on what paper work you have with it.
Vespa 90
Vespa 90
Hi,
Thanks for the information, I believe it is a UK bike but have no paper work with it. I will contact The Veteran Vespa Club for a dating certificate. From the image would you make the Vin number 21314?
@neil_edgar avatar
@neil_edgar avatar
That's what it looks like to me. As already confirmed, making it a 65 V90.
Is the bike all original?
Vespa 90
Vespa 90
Original apart from the front and rear light lenses and very low mileage not perfect but original. Thanks for your help.
V55 / 5 form. Go online and Google how to do it.
I followed this link on how to do my spanish import
https://www.spannerrash.com/how-to-fill-in-a-v55-form/
[ Time: 0.0130s ][ Queries: 4 (0.0053s) ][ live ][ 313 ][ ThingOne ]
