@isilentp avatar
2020 Vespa GTS SuperTech 300 HPE
@isilentp avatar
So the manual (online/PDF) has recommendations for tire pressures for the 2020 Vespa GTS SuperTech 300 HPE. They are listed in "bars"--no problem, thanks to Google, I was able to convert bars to PSI. However, I don't know why Vespa has decided to only publish recommended tire pressures for riders who also have a passenger along for the ride. I searched the internet up and down without finding anything from Vespa about the recommended tire pressure (either in bars or PSI) for single riders.
This is somewhat frustrating [ Facepalm emoticon ], so I am coming here to this wonderful group to ask the question: Has anyone seen ANYTHING (preferably from Vespa) pertaining to recommendation on tire pressure for single riders?
What does the label inside your glovebox suggest? A picture might be helpful, in case of mis-interpretation...
@burt37 avatar
GTS 300 SS BB
@burt37 avatar
GTS 300 SS BB
As per manual:
Front tyre: 28 PSI Either single or double
Rear Tyre: 36 PSI Two up or single with luggage..
If you want to be comfortable by yourself:
28 PSI front
32 PSI rear
PS A single rider should be around 60-70 kg. Anything higher go 36 on the back
@isilentp avatar
@isilentp avatar
Now why didn't I think of that? Checking now. Thanks!
Tire pressure in the Supertech manual pdf that i have show both with and without passenger
Front 1.8 with and without
Rear: 2.0 without, 2.2 with
I personally use 27psi front and 29 rear
Tires pressure
Tires pressure
@isilentp avatar
@isilentp avatar
Thanks, for the info!
steelbytes wrote:
Tire pressure in the Supertech manual pdf that i have show both when and without passenger
@isilentp avatar
@isilentp avatar
I saw that on the online manual, I will check the old fashioned paper manual as per prior response says it's in the paper manual.
@isilentp avatar
@isilentp avatar
So I checked the sticker in the glove compartment (Thanks, JimC). Below is the picture of the sticker along with the current tire pressure. I will make the necessary adjustments to the pressures in the morning. Thanks everyone for your help and suggestions.
This is for a 2020 Vespa GTS SuperTech 300 HPE.
@nightwing avatar
Contributor
2007 LX 150 (memories)
Contributor
@nightwing avatar
@isilentp avatar
@isilentp avatar
Now I have!
NightWing wrote:
@sdg avatar
63 GS160 MK1 / GT60 / Sean Wotherspoon
@sdg avatar
When it's hot season run them 26-30 when it gets colder run them at 27-32. I'm a reliable source promise.
SDG
interestingly that was from a PDF (1Q000743) I found online for the Supertech 300 (I think european?)
I just checked the manual (1Q000770) for my Supertech 300 (2019 asia pacific) and it has the following:
front 2.0 bar
rear 2.3 without and 2.6 with.
surprised that it's so different to the pdf and to your sticker .....
pressures
pressures
@isilentp avatar
@isilentp avatar
The uncertainty continues. I just checked the paper manual (20210825_102438 - 0001 - Edition of the Paper Manual (01_03-2019 Cod 1Q000748 (US-FR-ES-PT)) and it is different than the sticker... Notice my manual is an older version than that of 'steelbytes'.
The inconsistency makes it very confusing, but I think the sticker is probably the one that is most applicable to the bike. Thoughts?
Tire pressures according to the paper manual (01_03-2019 Cod 1Q000748 (US-FR-ES-PT))
It's also down to the rider's weight, and also their own preference for the 'feel' of the bike. Personally I use 200 mbar over the recommendation, so for single rider 2.0 bar front, 2.2 bar rear. Whatever that is in psi...
@guzzi_gal avatar
Gigi, '13 GTS 300ie Touring
@guzzi_gal avatar
I use what's recommended... Except when I don't. Razz emoticon (death-wobble mitigation=higher front psi)
26psi-front
29psi-rear
Now I'm wondering what a "sparg plug" is. Razz emoticon
@jayhawk avatar
@jayhawk avatar
It's the tiny plug inside a standard spark plug that no one is willing to talk about...
@burt37 avatar
GTS 300 SS BB
@burt37 avatar
GTS 300 SS BB
This is very quickly starting to look like an oil thread... ROFL emoticon
@isilentp avatar
@isilentp avatar
Interesting, but I would not want to try this on a scooter.
@burt37 avatar
GTS 300 SS BB
@burt37 avatar
GTS 300 SS BB
If you think that's bad, Aboriginal people are actually doing all the times with cars, but then again they don't ride on tarmac...
Watch the whole series, if you want to see the tyre bits...
[ Time: 0.0128s ][ Queries: 4 (0.0051s) ][ live ][ 313 ][ ThingOne ]
