@mjrally avatar
@mjrally avatar
Anybody ever come across this? Obviously replacing this stock PX150 crank ASAP.
parallelogramerist
parallelogramerist
Ugh, not that bad, but i used to have a TS1 240 kit that had a crank that rubbed on the webs. I dunno what caused my web rub, but i ended up throwing away the (expensive) crank and sold the cylinder kit.
@chandlerman avatar
Lucky
70 Days Since Last Explosion
Lucky
@chandlerman avatar
That's ugly looking. Is it just on the one side?
I don't know what's causing it, but I'd guess bad casting of the conn rod if it's one side or too much clearance between the webs if it's both?
@qascooter avatar
@qascooter avatar
Dang...Gnarly.....
@mjrally avatar
@mjrally avatar
Just the one side. 6K mile stock crank from my 05 PX.
Brass shims on the big end bearing aren't that worn. Bearing doesn't feel bad with the heel of your hand feel test.
Wish I had a jig to check run out.
parallelogramerist
parallelogramerist
That's very peculiar that it would happen on a "newer" PX150. Stock, hose engines are so darn weak that i wouldn't think that a simple seize could cause the con rod to get bent. I've never heard any bad reports before on the 2005 PX150 cranks...until now. Lemme ask, so is it still the original crank, or has it been replaced before in the past by someone else? Or maybe someone dropped the crank during a prior rebuild?...but i can't think of any reason that a 2005 PX150 would need to be rebuilt with less than 6k on the engine.
@mjrally avatar
@mjrally avatar
It's got the piaggio logo cast into the connecting rod. Don't know if that means anything other than stock. I opened it up to install the Malossi 24/63 overdrive kit on it and found the rubbing.
Anyone hear of bent cranks caused by using the electric start on a hydro locked motor? Ural (Russian sidecar bikes) have a bad reputation for wrecking cranks that way. Made me wonder if the same thing could happen here.
parallelogramerist
parallelogramerist
I don't think the PX's E starter has nearly enough torque to bend the rod in a hydrolock situation. I've hydrolocked my PX200's engine before (the cylinder filled up with fuel). I didn't realize it was hydrolocked and i tried kicking the engine over, but no way was the piston going to budge.
Jet Eye Master
Jet Eye Master
Twisted crank would be my first guess. If straightened, it's still ok to run with that rod.....for as long as it lasts.
So you didn't know until you saw it? No unusual noises? It almost looks like it was machined in there by the regular finish, and not rubbing by the same even color same as the rest. Have you looked inside the web, any metal to metal contact?
Maybe an insurance clearance cut when it was machined for rods that are a bit off sideways but otherwise useable? The distance from big end pin center to the edge of the web appears a little longer than to the edge of the odd area for what it's worth. Odd. :?
@mjrally avatar
@mjrally avatar
No noises or anything unusual. Just something I found during the strip down. I ride this scoot once a month or so. Just around town and then park it till the next time. It has always been too slow (150 gearing) to take it any distance. I bet I've put less than 500 miles on it in total.
The web itself looks pristine. No marks, burrs, blueing, smooth spots etc. The rod was the sacrificial piece. Buying a replacement and tossing it unless someone wants it to dissect.
[ Time: 0.0114s ][ Queries: 4 (0.0022s) ][ live ][ 313 ][ ThingOne ]
