@rolledoats avatar
2021 GTS 300 Super Sport
@rolledoats avatar
After an unfortunate string of 5 punctures in 8 months on my motorcycle (yes, I'm unlucky), I've gotten in the habit of checking my tires before every ride.
With my motorcycle, I can put it on its center stand, put my hand under the front fork (by the axel), lift up, and the front tire comes off the ground just enough so I can spin it. This makes examining the tire condition / moving the pressure valve to a more convenient position very simple. Tried doing the same thing with my GTS and it's not quite as easy.
Is there a good way of doing this with a Vespa? Or should I just get used to walking it forward a bit and checking the tire that way?
@attila avatar
@attila avatar
Look for the causes, you can't live with the nightmare of punctured tires.
I use a concrete block with a scrap of 2x6 as pad under the floorpan but ntend to make a light wooden box to save my back.Thanks for the reminder to check the scrap pile at HD.
@touring300 avatar
@touring300 avatar
Using the pet carrier turned upside down works well.
@sdg avatar
63 GS160 MK1 / GT60 / Sean Wotherspoon
@sdg avatar
Visual inspection and spray bottle of water. Also if you lost psi
after 3-4 days you have a problem.
SDG
@syd avatar
GTS300 Super (Heinz) GTS250 Super (Bulger)
@syd avatar
Have your wife / SO sit on the pillion seat.
@madison_sully avatar
Move.
Seriously, get away from the construction site or factory, whichever it is.
[ Time: 0.0116s ][ Queries: 3 (0.0041s) ][ live ][ 313 ][ ThingOne ]
