I'm not good at English. sorry. It will be vespa gt200. The seat opening / closing motor does not work. When you press the button, 12v is coming to the connector. All fuses are normal. It works normally when 12v is passed directly to the motor. The headlight is LED. The headlights turn off frequently. What is the cause?
It was completely cured. I replaced the main harness. The broken harness will be verified at a later date.
@berto avatar
@berto avatar
That's one way to fix it!
I'm glad you solved the problem.
[ Time: 0.0094s ][ Queries: 4 (0.0021s) ][ live ][ 313 ][ ThingOne ]
