Vespa GTS 125ie Super
Greetings everyone,
I need some help please. My 2015 Vespa GTS 125 Super has started sputtering at low acceleration, and a bit when I gain more speed. It doesn't cut out and at idle sounds pretty stable. It has around 28,000 miles.
I'm not a mechanic, I do know a little, but please speak plainly. I would appreciate any help. 🙏🏼
@gtdespatchcourier avatar
GTS 300ie
GTS 300ie
how long since it was last serviced? it might be due a spark plug change/air filter clean/oil change/transmission service etc ?
Thank you for the reply. The service was probably about 2000 miles ago. I've changed out the belt, rollers, sliders and air filter much sooner than that. I've also changed out the spark plug much much sooner. The oil probably needs some changing though. Has not had a transmission service recently. Howeive kept an eye on the transmission fluid levels/colour and was at level and colour normal. What does a transmission service entail?
Many thanks.
-chris
@touring300 avatar
@touring300 avatar
The transmission service is what you have already done, i.e. belt, rollers, sliders and general clean-up inside the transmission cover.
You have not mentioned doing a valve check, if it's never been done, your scooter is way over due to have it done and it could be the source of the symptoms you are describing.
[ Time: 0.0126s ][ Queries: 3 (0.0043s) ][ live ][ 313 ][ ThingOne ]
