vespa gts250
vespa gts250
So yesterday after two 50 mile trips in one day the CEL has decided to come on and stay on, everything seems fine, runs ok, gonna check coolant level but it was on as soon as I start it while the engine was cold in the morning today too?
Anyone know what it could be? Bike has 3600 miles
0:7 And counting
0:7 And counting
It's not the coolant. I don't have any experience with the HPE, but historically, the biggest driver of the check engine light is the O2 sensor -- either disconnected or failing.
vespa gts250
vespa gts250
So should I take it in or wait for it to go away? My old bike had lambda sensor reading issues all the time but it never did anything!
0:7 And counting
0:7 And counting
I think it's worth taking in so they can read the actual fault code and diagnose the problem.
@retro_scoot avatar
2020 GTS300 HPE "Whiskers"
@retro_scoot avatar
If it came on soon after refueling, it's almost certainly the vapor recovery system/02 sensor. Mine has done it twice in some 3,500 miles. I spoke with my dealer and he said if it's running good and if the oil level was good and not over-full (BOTH of those oil-related things he stressed) then just ride it and it should go out on its own. In both cases my light went out by the next day of riding. I did crack the gas cap in both instances to vent the pressure (then retightened) FWIW and took more care from then on when refueling so as not to slop any fuel down the drain hole or try to fill it to the brim. (I'd been a little sloppy in the past) Just another quirk in my book but nothing to fuss about.
Bike runs like a champ with zero issues. I don't worry about it. Hope that puts your mind at ease.
vespa gts250
vespa gts250
This happened like 15 minutes after refilling, it's still there today but I think it'll go away as I burn gas! Same here nothing is running different!
[ Time: 0.0104s ][ Queries: 3 (0.0026s) ][ live ][ 313 ][ ThingOne ]
