65 small frame and 64 large frame Allstate
Got a new cylinder and piston to replace the seized ones that came with my project Allstate.
Question is, so I need to hone the cylinder before assembly? No marks whatsoever on the bore right now.
@gickspeed avatar
@gickspeed avatar
Probably not. I would clean up the port edges though. . . They are especially bad on economy cylinders.
Did find some rough and sharp edges on the ports. Cleaned them up with a diamond file.
I presume chamfering the edges keeps the rings from hanging up on the port edges?
Also the aluminum head gasket overhung the ports slightly in a couple of spots so I cleaned those up too, or am I being too anal now?
Another question, paint the cylinder with high heat paint or not?
@gickspeed avatar
@gickspeed avatar
Why? It is a new cylinder. Get it prepped and install.
[ Time: 0.0106s ][ Queries: 3 (0.0035s) ][ live ][ 313 ][ ThingOne ]
