Piaggio Typhoon 125
Piaggio Typhoon 125
I had a no start problem and removed conical/diaphragm = bad move. The no start problem was a loose plug at rectifier.
Now Piaggio Typhoon 125 won't go over 35 mph. Runs good till it hits 35mph. Used to go 55mph before I messed with carb. Any ideas?
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
I'm confused - did you remove the needle and diaphragm and now you have the issue? Or are you saying you removed them to work on it, put them back in, but now there is an issue?
I'm not familiar with the specific carb (is it this one? https://oem-parts.hu/en/parts/piaggio/typhoon-125/2014/typhoon-125-4t-2v-e3-2010-2016-apac/engine-carburetors-components), but you definitely need the needle in for it to run correctly
@greasy125 avatar
@greasy125 avatar
Your diaphragm isn't sealed/seated properly. Or the needle is hung up not set correctly. Or the spring is bound up on the slide and cover.
Take it all apart and do it again.
If the diaphragm is being pesky a little dab of grease helps to hold it in place.
Piaggio Typhoon 125
Piaggio Typhoon 125
I took it apart again and put the diaphragm and needle back in again. It still won't go over 35 miles per hour. Am I missing a part? Shouldn't the needle have a clip for height adjustments?
@greasy125 avatar
@greasy125 avatar
there is no clip or adjustment. needle goes in, the retainer with the prongs goes on top, then the spring goes on and it indexes both the retainer and the post on the cover. it is possible to jam it all together and bind the spring and thus the slide won't lift and you'll have poor performance.
my guess, though, is that you didn't get the seal on the diaphragm either between the cover or the carb body.
put it all together and shoot some air thru the inlet side of the port, into the diaphragm port. it should actuate it and lift the slide. if not, you don't have a seal or you messed something else up.
also, that's dirty as all get out. clean that mess up before reinstalling.
You could have dislodged some of that dirt and it's partially blocking the main jet. Clean it all again - and then again! I had to clean my GT200 carb about five times after it'd been left unattended for eighteen months. Gawd knows what condition it'll be in when I eventually get back to Blighty for a visit.
Piaggio Typhoon 125
Piaggio Typhoon 125
I fixed the slow speed problem by filling the groove in carb body with grease so that the diaphragm would stay in groove. Thanks Greasy 125 Clap emoticon
The original problem of a hard start and sometimes no start is back (I guess it wasn't the loose plug at rectifier). I believe it's electrical, possibly a weak spark. I will post a new thread for this problem after I try a new plug.
[ Time: 0.0100s ][ Queries: 4 (0.0022s) ][ live ][ 313 ][ ThingOne ]
