@themayor avatar
GTS 300 (2021)
@themayor avatar
GTS 300 (2021)
Subject says it all. Filling the GTS 300 tank is a PITA - maybe worse in California where the gas hose has the "collar" you need to hold back. Am I missing something? Driving me nuts.
Just like any MC, it's painful innit?
⚠️ Last edited by Topolino on UTC; edited 1 time
@capscoot avatar
2022 GTS HPE "Shadowfax""
@capscoot avatar
Check out Robot's video:
Open gas cap - lift petcarrier and place gas cap at the back to keep petcarrier raised.
Insert nozzle as far as you can with it pointing towards the rear, the handle towards the front.
Pull up the foreskin with left hand as far as you can. Pump until the first click-off. Do not attempt to top up.
@capscoot avatar
@capscoot avatar
Oops, faster than I was.
@themayor avatar
GTS 300 (2021)
@themayor avatar
GTS 300 (2021)
Shoulda known there'd be a Robot video!
If Robot had inserted the nozzle orientated as I suggested, I doubt he'd have had a slight spill. OK, some pumps cut-offs can be a bit slow, but most CA ones I've met are just fine. If you fill from the side, as he did, you may get a spill regardless.
@attila avatar
@attila avatar
jimc wrote:
Pull up the foreskin...
The translator tells me "foreskin" which we use only in anatomy to indicate the anterior part of .... ouch ... penis.
0:7 And counting
0:7 And counting
Your translator is not wrong. That's Jim's derisive term for the vapor-recovery sleeves on California gas pumps.
@attila avatar
@attila avatar
Ah ... it was intentional, hahaha ... now I understand the metaphor; sorry for the request.
[ Time: 0.0102s ][ Queries: 3 (0.0018s) ][ live ][ 313 ][ ThingOne ]
