I know smallframe vespas have the notorious duck fart horn, does anybody know if there are any improved ones on the market? My pk xl 75 is really duck farty but too quiet although it passed its MOT test. Would replacing the horn be the best move as worn out possibly internally or is there a better one out there? Thanks
@safis avatar
@safis avatar
Since it's AC a new horn won't make a significant difference. Maybe a bit better but it will still sound like a duck. This was the main reason (and the SIP speedo), I put a battery on my P. There's a horn rectifier which converts AC to DC and then you can use a regular DC horn but it's a bit costly. PKs on certain markets had it from the factory cause a normal sounding horn was a requirement. Since it's a discontinued product by Piaggio, SIP and SC make their own. SC's is more advanced (has a USB charger output and an LED flasher relay)...
SIP
https://www.sip-scootershop.com/en/product/horn-rectifier-sip_99260200
SC
https://www.scooter-center.com/en/horn-rectifier-incl.-adapter-wire-bgm-pro-with-blinker-relay-for-led-indicator-and-usb-charge-plug-bgm6710kt1?number=BGM6710KT1
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
Weirdly, the horn on my ET3 is bold and clear and loud. It's my battery P200 that has the duck fart.
It's interesting that you say this. Of all four of my bikes (three large frames with each having no battery), my small frame 90 with no battery has the loudest most obnoxiously high pitched horn, which I love in hectic city traffic. Incidentally, my PX150E horn is the weakest sounding of all four. If the headlight is on, then it's louder.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Ditto. The AC horn on my smallie beeps loud and clear. The DC on the Soop squawks like a sick goose.
SIP
SC
Thats really interesting, its not too expensive really. Thank you for sharing. I took the PK XL for its MOT test at a hardcore Harley Davidson repair shop and dealt with the most obnoxious greaser ive ever come across who questioned the horn for the MOT. I told him to rev it a bit harder and it sounded more like a duck in mating season. Anyways, it passed so jobs a goodun.
@safis avatar
@safis avatar
FYI, if you'll go that route, you'll need a different light / horn switch and some wiring mods to make it work...
@scootnewb avatar
P200
@scootnewb avatar
P200
If my horn was loud and clear I'd be working hard to get the duck fart back.
@modkuo avatar
'79 P200, '74 VBC Super, '77 P125 Project, 1978 Rally 200
@modkuo avatar
I love pulling up to the meetup spot and letting out a long hornfart.
It...so...goes with the scoot. Not safe for traffic but gets a chuckle or two fo sho.
Razz emoticon
@kevin_harrell avatar
1980 Honda Twinstar and 2004 Yamaha V Star
There should be some sort of adjustment screw on the horn. Find this screw, play with it till it sounds better. Some sort of penetrating oil in the horn could help too.
This method helped my horn on a 6 volt motorcycle, and also, on some 3 volt bicycles.
[ Time: 0.0097s ][ Queries: 3 (0.0035s) ][ live ][ 313 ][ ThingOne ]
