@garncarz avatar
1964 Allstate Cruisaire, 2022 Husqvarna Vitpilen 401, 1972 Suzuki T500J
@garncarz avatar
My '64 Allstate was missing a front wheel stud when I bought it. I am having a hell of a time finding a replacement stud: M10x1.5. Anyone have a source? Thanks in advance.
Do you have a pic of what you need? I have the front wheel assembly that I took off my bike when I swapped to 10" wheels.
@monza avatar
63 VNB
@monza avatar
63 VNB
Its not just a stud. There is a thin head on it and its welded into the axle assembly. I'd clean up the old weld and hole, get a black oxide bolt, thin the head down and install like factory with some welds. Don't try to weld zinc/galvanized.
I've got the whole shebang so to speak. PM me if you'd like it.
@garncarz avatar
@garncarz avatar
I just sent you a PM.
@garncarz avatar
@garncarz avatar
What you posted looks exactly like the front axle from my Allstate.
^^^ That's your best solution. And monza is right, a stud might work welded in properly, but you'd be a lot better off with one of these for this kind of repair. You could grind the head down flatter as needed:
this one is hi strength alloy, 10x1.5 x 25mm long, and you can buy just one for 47 cents.
https://www.belmetric.com/m10x15-coarse-thread-c-6_341_1445_379_2386/sb10x25-button-head-109-black-p-13517.html
[ Time: 0.0125s ][ Queries: 4 (0.0041s) ][ live ][ 313 ][ ThingOne ]
