Vespa sportique 150 vbb
Hope someone can shed some light on this , my vbb 150 tends to jump once I let the clutch handle out and makes like a slipping of the gears noise for a second then goes , if I push off and release the clutch under lowing revs it doesn't jump or make a noise. I have tried adjusting the clutch cable a little bit sure how far to adjust though , Baffled by this , tia
@stickyfrog avatar
Moderatus Rana
MP3 250 and 2 MP3 500s
Moderatus Rana
@stickyfrog avatar
Welcome to Modern Vespa. I moved you to NSM area of the site where you will get more answers for you problem. Good luck.
@gickspeed avatar
@gickspeed avatar
Poor separation between the outer edge of the clutch base plate and the clutch gear.
Use this: https://www.sip-scootershop.com/en/product/spacer-cosa-2-cosa-2-clutch-24-5x15-2x0-8-mm_69821000
Thanks for the info. I will check/ fit one 👌👍🏽
@subetherbass avatar
Firstly... hiya & welcome.
Second... hopefully your VBB isn't a bodge (if you don't know what that is, check out "bodgespotting"
Thirdly... pics please, it's our version of porn.
Fourthly... what Gick said, or it hasn't been ridden for ages & plates are gummed up & sticking together, or crucifirm, or bad adjustment, or you were expecting it to work like a twistie.
[ Time: 0.0098s ][ Queries: 3 (0.0016s) ][ live ][ 313 ][ ThingOne ]
