Thu, 02 Sep 2021 05:04:25 +0000
79 P200E (Ruby), 62 Allstate (B-62), 2008 Stella (Olive)
Thu, 02 Sep 2021 05:04:25 +0000 quote
Some of you know that I've been given the opportunity of getting a 1980 white P200 up and running.
I'm going to document my progress and what I do to get this beauty back on the road. It should be a fun ride, bringing it back alive.
Yes, she's been named Bianca before she even is running. I didn't name her, my lovely wife did, but it fits, so there you go.
I haven't had any time to do anything, except put her on the table and take a few pics. Hopefully tomorrow I'll get to taking off the side cowls.
And I KNOW ScootNewB (Chris) will be over to help me drink coffee and eat donuts while we bring it back to life.
I do know:
It rolls, and the body seems straight,
The clutch seems to work,
The front and rear brake seem to work,
The engine turns (I gave it a push in 3rd and felt it burp).
I plan on:
Taking the cowls off
Drain the gear oil and inspect, refill if all looks good.
Pull the tank and clean.
Pull the carb, clean, and install.
Pull the Petcock (heh heh, petcock) and replace.
Fuel and oil line replace.
Oil tank and sight glass with new seals.
Visual inspect the electricals.
Pull the battery and replace with sealed battery.
Hook up temp tank and see if it'll start.
Here are the pics I took today to get the ball rolling...
Meet Bianca - Lived her life in Santa Cruz until 1990, then shuffled to Florence, Oregon and parked in the back of a shop for 30+ years
Broken headset
Slight crease in the legshield.
Front fender and grill has hole in it
Legshield dents at the bottom curve on both sides. Not huge though...
Center stand mount has tweaked floor
Glovebox needs some minor love to align it. Still has the serial number in tape on the inside of the legshield!
The BBQ rack was attached below the light mount, not to the license plate frame, which buggered up the body....
It still has the kill switch intact
And the plastic fuel lever. Gonna change it out for a euro style. I'll clean up this one as well as the fuel tap because someone may need it to do a period restore.
Turpentine anyone. It doesn't look too bad...
Thu, 02 Sep 2021 05:16:04 +0000
Rally 200
Rally 200
Thu, 02 Sep 2021 05:16:04 +0000 quote
Looks like a fantastic project, a sympathetic restoration maybe?
Anyway good luck with it 😎
Thu, 02 Sep 2021 05:19:48 +0000
Thu, 02 Sep 2021 05:19:48 +0000 quote
Thanks CGT. I plan on doing a refurbish, or get it rolling safely and solidly, clean it up, and call it good. I'm excited to hear it fire up for the first time in over 30 years...
Thu, 02 Sep 2021 13:24:09 +0000
VNB VSC o9c VMA vbc vmb VSX
Thu, 02 Sep 2021 13:24:09 +0000 quote
Right on.
Looks like a cleaner version of my P project.
Watching! Good luck.
Thu, 02 Sep 2021 14:01:16 +0000
P125X, P200E
P125X, P200E
Thu, 02 Sep 2021 14:01:16 +0000 quote
Wow! That looks it is going to be a fun project. Looking forward to watching your postings
Thu, 02 Sep 2021 23:03:59 +0000
1980 P200E
1980 P200E
Thu, 02 Sep 2021 23:03:59 +0000 quote
When you get started on the condition of the electrical I would be very interested in before and after pictures if your planning on posting them. I have a 1980 that sat quite awhile as well. Always liked the color white on the P200E. Looking forward to following your post and watch your progress. Good luck.
Thu, 02 Sep 2021 23:14:14 +0000
bodgemaster
bodgemaster
Thu, 02 Sep 2021 23:14:14 +0000 quote
If the tap works, I'd keep it. It's part of the bike's pedigree.
Thu, 02 Sep 2021 23:49:40 +0000
Thu, 02 Sep 2021 23:49:40 +0000 quote
Yep… 10 years ago Ida been fu#% that plastic thing… but now… if it works, keep it!
Fri, 03 Sep 2021 00:52:31 +0000
Lucky
76 Sprint V, 63 GL, 62 VBB, 05 Stella, 66 Smallstate, 08 Stella (for now)
Lucky
Fri, 03 Sep 2021 00:52:31 +0000 quote
That thing looks great!
Those dents will hammer out, just put some masking tape over the spots where you're hammering to protect the paint.
You're more patient than I am. I'd have poured some premix in the tank, shot some starter fluid in the carb, then given it a kick and give around the block to see if the brakes worked.
I'm looking forward to watching this project along.
Fri, 03 Sep 2021 11:26:38 +0000
Nedminder
Nedminder
Fri, 03 Sep 2021 11:26:38 +0000 quote
This looks like about a 2 pot of coffee 2-3 crueller job - depending on how much company comes over - in which case you may need to double?
Someone's going to end up with a nice scoot.
Tue, 07 Sep 2021 05:17:25 +0000
Tue, 07 Sep 2021 05:17:25 +0000 quote
Thanks everyone for the comments!
Well, she's alive and running! Chris came over and we pulled B-62s engine because of the big end of the Conrod knocking and loosey goosey, which is the topic in B-62s thread.
Anyway, that went real quick so we decided to take a look at Bianca.
We drained and replaced the gear oil. The oil that came out looked great!
Swapped the carb with a spare I have on the shelf,
Hooked up the test gas tank,
Kicked it over...Flippin amazing - started right up!
Then we did a little clean up - some 0000 steel wool and various lubricants, and some polish. She's going to clean up nice. Real nice...
Can you tell which part I cleaned?
Chris gave it a quick polish!
Clean, over 30 year oil
Sticky, filthy carb. Needs some serious cleaning. But it's a 24/24!
Tue, 07 Sep 2021 13:37:52 +0000
Rally 200
Rally 200
Tue, 07 Sep 2021 13:37:52 +0000 quote
Wow, looking and sounding fantastic, keep the thread updated please.
Tue, 07 Sep 2021 13:51:02 +0000
Lucky
Lucky
Tue, 07 Sep 2021 13:51:02 +0000 quote
Hah! I love a good first start video
And it's great to see another scoot back on the road, too. Nice work getting that one going. I hope it took some of the sting out of what you found in Bummer-52, too.
Tue, 07 Sep 2021 15:16:33 +0000
Tue, 07 Sep 2021 15:16:33 +0000 quote
You are right on the money CM - Chris was saying how the day was "Sweet & Sour". It was a day that balance swung to both sides of the pendulum.
But I think, I think Bianca is going to run without having to open her up. New tires, clean the tank, and we'll see.
Tue, 07 Sep 2021 15:22:33 +0000
P200
P200
Tue, 07 Sep 2021 15:22:33 +0000 quote
I'm sixty two years old but when I'm doing projects with Scott our thought process often reverts to that of ten year olds building something dangerous in the garage. First it's, HEY we can use this syringe for a portable fuel tank and quickly evolves into, let's duct tape the syringe to the backrest and try riding it😀😀😀
Tue, 07 Sep 2021 16:46:45 +0000
Lucky
Lucky
Tue, 07 Sep 2021 16:46:45 +0000 quote
You say that like it's a Bad Thing.
Tue, 07 Sep 2021 17:25:46 +0000
Tue, 07 Sep 2021 17:25:46 +0000 quote
Ah that looks great. Real patina. Look forward to more instalments
Tue, 07 Sep 2021 19:35:36 +0000
bodgemaster
bodgemaster
Tue, 07 Sep 2021 19:35:36 +0000 quote
Syringe is hi tech. We use a funnel.
Tue, 07 Sep 2021 19:46:03 +0000
Lucky
Lucky
Tue, 07 Sep 2021 19:46:03 +0000 quote
Now I'm not sure if my Miracle Whip jar is high-tech or low-tech. This hobby can be *so* confusing sometimes.
Tue, 07 Sep 2021 19:54:50 +0000
'74 50s x3 '78 P200 E '84 Cosa '91 PK50XL2 '58 AllState '68 Sprint '80 50special and a '66(?) Super125
Tue, 07 Sep 2021 19:54:50 +0000 quote
Depends, glass is low tech and ought be avoided for obvious reasons but I trust you are using safety rated high tech plastic jars here.
Tue, 07 Sep 2021 20:07:12 +0000
Nedminder
Nedminder
Tue, 07 Sep 2021 20:07:12 +0000 quote
Nothing like a funnel of petrol sloshing around over a hot engine to keep things interesting.
At least you're spending your time imagining containers, lamps, what not, into gas cans rather than bongs. Times change.
Of course - that P200 motor would also fit in B62 should it need a loaner...
Wed, 08 Sep 2021 01:57:35 +0000
Wed, 08 Sep 2021 01:57:35 +0000 quote
Heh heh - times change indeed. And you KNOW I've thought about it, but naah, Bianca is too sweet to be yanking the engine and playing mix and match. I'll just work on them both until they're both running and solid. We'll see which one gets done first!
Wed, 08 Sep 2021 01:59:50 +0000
Wed, 08 Sep 2021 01:59:50 +0000 quote
We at least made a duct tape cap complete with knifeblade air vent in the top! Super safe!
Fri, 17 Sep 2021 01:42:36 +0000
Fri, 17 Sep 2021 01:42:36 +0000 quote
I had a few minutes today so I pulled the spare tire and battery. Battery acid did a number on stuff in there.
I gave it all a quick wipe down and will wire brush the rust off the battery holder, paint it, then put a sealed battery back in.
I'm debating on putting an LED flasher and new fuse block in. We'll see...
Pretty fugly
Battery box needs some love
Managed to remove this rusted bolt with kroil and vice grips. The head was rusted off
It's looking a little better in there now....
Fri, 17 Sep 2021 10:10:40 +0000
The Dude
The Dude
Fri, 17 Sep 2021 10:10:40 +0000 quote
Following along. Bianca is a beaut already! Syringe fuel tank for the win. Double points for duct tape cap - with vent
This is a fun one already. I like the plan
Fri, 17 Sep 2021 11:53:59 +0000
2007 Stella 225
2007 Stella 225
Fri, 17 Sep 2021 11:53:59 +0000 quote
I put an electronic flasher in mine and it made the standard bulbs brighter. Long story short a standard flasher drops voltage during normal operation and an electronic flasher drops much less. I posted about It previously with measurements.
Fri, 17 Sep 2021 12:59:18 +0000
64 V90 survivor '65 Allstate survivor. '75 V90 SOLD. '77 P200 SOLD
Fri, 17 Sep 2021 12:59:18 +0000 quote
Scott
You are making good progress. Interested in following progress with electrics.
Thinking of changing indicator bulbs to led on the 77P200 I just bought and will pick up next week and will need to change flasher.
Following along.
Sat, 18 Sep 2021 04:51:04 +0000
Sat, 18 Sep 2021 04:51:04 +0000 quote
This is the flasher to get:
https://www.superbrightleds.com/moreinfo/flashers-load-resistors/fl3-red-led-bulb-electronic-flasher/780/834/
It'll run Leads, incandescent, or a mix. I've been using. This flasher on a 79 P200 for a long while now. It works great.
The flasher
The proper hookup of the wiring
I found that putting it in the rubber holder, then install the rubber is easier than cramming the square relay into the rubber mount while the mount is attached
Sat, 18 Sep 2021 05:08:38 +0000
P125X, P200E
P125X, P200E
Sat, 18 Sep 2021 05:08:38 +0000 quote
Yes, that is the flasher I use for LEDs in my 4 turn signals. I had an led tail light too for a while but it burned out and I haven't gotten around to replacing it yet. Right now I'm just using the stock filament bulb in the tail light and the combination works very well.
Sat, 18 Sep 2021 05:36:45 +0000
Sat, 18 Sep 2021 05:36:45 +0000 quote
I pulled the tank today! I had to stick it outside. It stunk so bad the smell was making it into the mudroom
I pulled the fuel tap and think I'm going to give electrolysis a go.
Gonna go to a secluded place called Sunset Bay for a few days first for some R&R.
Tunnel cover caught some oil
The fuel tap isn't super bad. It might just clean up and be usable. No, changing it out...
The tank, in a bucket
It's nasty in there...
Sat, 18 Sep 2021 08:50:11 +0000
The Dude
The Dude
Sat, 18 Sep 2021 08:50:11 +0000 quote
Nice work so far. Chipping away.
Have you considered Evaporust for the tank? I know electrolosis is a popular choice here, but it does take a long time and can be a bit difficult to get all the various nooks-n-krannies totally clean. It is a fun and interesting process! I've used it for numerous projects. At one point I had a 5gal bucket lined inside perimeter with wire mesh, suspend small parts in the center, worked great.
Evaporust is safe and quick, not too expensive either IMHO. Works in hours, not days. Fill tank, seal it, turn it around every now and then. Drain - done. In one afternoon/overnight. reuse the solution if not too bad. Keep a small bucket full, drop in parts anytime. I'm a fan.
Sat, 18 Sep 2021 08:58:49 +0000
The Dude
The Dude
Sat, 18 Sep 2021 08:58:49 +0000 quote
thanks for the flasher link. Very helpful. These electronic type flashers can be used with incan or LED bulbs, so its a worthy replacement on various scoots. I have a similar unit on my smallie, but its 2-prong, from CEC #EF32SS-R Flasher.
Sat, 18 Sep 2021 11:39:08 +0000
Sat, 18 Sep 2021 11:39:08 +0000 quote
Have you considered Evaporust for the tank?.
Thanks GL - I wasn't but I am now! Sounds like some good stuff and a no brainer. I've used vinegar for numerous jobs but it is a slow process.
Thanks for the tip - I'll check it out!
Sat, 18 Sep 2021 11:40:26 +0000
Sat, 18 Sep 2021 11:40:26 +0000 quote
Scott
Thanks for the flasher link.
Sat, 18 Sep 2021 15:46:03 +0000
bodgemaster
bodgemaster
Sat, 18 Sep 2021 15:46:03 +0000 quote
+1. Or look for a product called "Metal Rescue". It's similar to EvapoRust and about the same price ... in my experience, actually works a little better/faster.
Whichever you use, warming the product (and the part) speeds up the de-rusting process significantly.
Sat, 18 Sep 2021 18:48:28 +0000
Sat, 18 Sep 2021 18:48:28 +0000 quote
After you get rid of the nasty goo , you are probably thinking of one of the methods to fill it with nuts and bolts, rocks and sand whatever, and your favorite detergent or phosphoric/muriatic acid or juice of your preference, then shaking the daylights out of it for a while to get it cleaned and derusted well...
Lots of ways to get it well shook up, but a clever one I saw lately was a guy jacked up one back wheel on his rear wheel drive car, and bungeed his motorcycle tank to the spokes of the mag style wheel, put it in low and let it idle. Run for a while, then rebungee on a different axis. Worked like a champ and was clean as a whistle.
Also, you might try flushing w/ strong solvent(acetone/lacquer thinner?) to dissolve and remove most of that goo before you attack the rust.
Sat, 18 Sep 2021 19:08:28 +0000
Sat, 18 Sep 2021 19:08:28 +0000 quote
Thanks V - I was planning on letting it soak with some degreaser or something stronger and slosh it around a bit before taking it to the naxt level....Maybe I should try the acetone first....
Thanks for the tip!
Sat, 18 Sep 2021 22:08:52 +0000
Lucky
Lucky
Sat, 18 Sep 2021 22:08:52 +0000 quote
I got a wire wheel for my drill, then put that on an extension rod and started that way. It got rid of a huge amount of rust, so all the other methods had a lot less work to do.
Brush on a stick
Mon, 27 Sep 2021 18:32:14 +0000
Mon, 27 Sep 2021 18:32:14 +0000 quote
Managed to do a bit on Bianca.
I ospho'd and painted the battery box, put dielectric grease on all the electrical fittings behind the battery box, and installed a sealed battery.
Next up, clean the tank, tank cavity, and carb...
Dielectric grease on all connections
Painted battery box and soaked rubber bits installed
Battery installed a la zip ties.... I'll get a strap at some point...
Mon, 27 Sep 2021 19:18:33 +0000
Mon, 27 Sep 2021 19:18:33 +0000 quote
Scott
Where did you get the sealed battery I'll be needing one soon.
  DoubleGood Design
[ Time: 0.0635s ][ Queries: 6 (0.0316s) ][ Debug on ][ 281 ][ Thing Two ]
