Thu Sep 02, 2021 1:59 pm
Thu Sep 02, 2021 1:59 pm linkquote
Went for a ride 2up, stopped for lunch
The parking lot wasn't level
I swung through a spot, so I was facing out, as is my habit on 2 wheels
Locked the front, paddled back a few steps, pulled forward, locked the front, started paddling back, brushed the tilt lock switch
My brain thought I dropped it, hit the kill switch, stepped off on the low side, slapped my wife's boot off the seat onto the ground [she also was sure it had gone wrong]
Centered up the bike, locked the tilt
Never hit the ground, not a busted mirror or a bent lever
All was good, had a nice lunch
Lesson
Lock the front, turn off the key before attempting advanced parking maneuvers
My brain says don't park going up hill, as getting a big bike off a centerstand can be tough, MP3 says no problem rolling backwards 2up tilt locked
Sat Sep 18, 2021 4:38 pm
Sat Sep 18, 2021 4:38 pm linkquote
Happy to hear it ended this way!
Sun Sep 19, 2021 4:36 am
MP3 500, GTS 250 (both 2008 MY), 2012 Honda NC700 DCT, 2014 Can Am Spyder RT
Sun Sep 19, 2021 4:36 am linkquote
Garthhh wrote:
Lesson
Glad it turned out well, but I have to disagree with you on this.
If you move the scooter anywhere with the wheels locked, and encounter a hole as shallow as an inch, you can tip over. Personally, any time I had a pillion, I'd never activate the tilt lock until I was parked where I wanted to be, or at least where the pillion was to dismount. If I wanted to move the scooter after the pillion dismounted, I'd do that. But I never move the scooter with a pillion, while the tilt lock is engaged. YMMV.
Sun Sep 19, 2021 1:27 pm
Sun Sep 19, 2021 1:27 pm linkquote
In my increasing decrepitude, I know going slow or stopped is when it goes wrong most often
I park on the front of 1 1/2 car long parking space, with an empty spot next to me
I roll backwards & do a Y turn at the start of every ride with or without pillion
Sun Sep 19, 2021 5:26 pm
2019 MP3 500 Sport
2019 MP3 500 Sport
Sun Sep 19, 2021 5:26 pm linkquote
With any motorcycle I think the vast majority of "incidents" are drops at a semi-standstill. It certainly is the case for me. I did drop my MP3 like juat 3 days after buying it. the false legend about the 3 wheel stability suckered me. But zero damage happened. Phew.
Sun Sep 19, 2021 10:39 pm
2008 fuoco
2008 fuoco
Sun Sep 19, 2021 10:39 pm linkquote
I'll second that. Thats why i did the "mono" mod.
Mon Sep 20, 2021 6:38 am
Mon Sep 20, 2021 6:38 am linkquote
Mono Mod?
Mon Sep 20, 2021 9:06 am
2015 MP3 500 ie Business
Mon Sep 20, 2021 9:06 am linkquote
Has this just become a audiophile forum?
I'm looking forward to learning about the Dolby and/or DTS mods then.
Wed Sep 22, 2021 4:24 am
2008 fuoco
2008 fuoco
Wed Sep 22, 2021 4:24 am linkquote
Garthhh wrote:
Mono Mod?
Take a look at the thread "Tilt lock modification,or fix " by mono.
Wed Sep 22, 2021 4:27 am
2008 fuoco
2008 fuoco
Wed Sep 22, 2021 4:27 am linkquote
No, i'll say it in stereo. No. See above.
Wed Oct 06, 2021 12:42 pm
Piaggio MP3 300 HPE
Piaggio MP3 300 HPE
Wed Oct 06, 2021 12:42 pm linkquote
I had this today. At 6am, I was so excited at seeing an open petrol station with no queue that I did a slow u turn on a thankfully empty road. I was covering the front and rear brake and for some reason, I hit the front brake as I turned, which caused the bike to slow, and lean more. Realising something was wrong, I instinctively pressed the brake harder and the bike tipped. Luckily I was fine and a nice white van driver came out to help me pick up the bike. I then tried to wheel it into the petrol station but it was rather heavy, so I engaged tilt lock. Then I hit a hole in the road and it then tipped the other side. Serious rookie mistakes which I put down to the early morning!
Few scratches on the plastic and on the side of the handlebar grips but nothing serious.
So - if on the road, do not use tilt lock if you are wheeling it about.
Wed Oct 06, 2021 1:32 pm
2008 fuoco
2008 fuoco
Wed Oct 06, 2021 1:32 pm linkquote
So i was out today on the fuoco and parked up to get petrol and also parked up looking at a honda dealers looking for a forza 750 to sit on.It still feels strange with the "mono" mod when parking and feeling the bike is no longer solidly held in position as the suspension is unlocked and will rock slightly , however when you are pushing the bike over a raised kerb ect it feels alot safer than it did as standard.I did however do something i normaly don't do except in the garage and that was to put it on the centre stand just in case.
Wed Oct 06, 2021 3:51 pm
2016 Piaggio MP3 500ie
Wed Oct 06, 2021 3:51 pm linkquote
I dropped my bike early last week. I was going up a very steep grade in downtown San Francisco and at the top I had to turn left to a very steep grade going downhill. Problem was only I had to stop but cars were blocking my view so I crept over the crest and turn left but it was too much. If I had kept the momentum and not stopped I would of been all right.
So there I was with my bike laying in the middle of the road in an incline so I could even pick it up. Lucky for me two ladies happened to be watching my folly and helped me get it up.
Amazingly nothing broke nor did the paint get dinged. But my engine did redline for a few minutes because tipping it split some coolant and the angle made all of it leave the motor for a time. But soon it went back to normal.
Thu Oct 07, 2021 10:26 am
Piaggio MP3 300 HPE
Piaggio MP3 300 HPE
Thu Oct 07, 2021 10:26 am linkquote
3legsofman wrote:
... looking for a forza 750 to sit on.
Me too!
Thu Oct 07, 2021 2:10 pm
Thu Oct 07, 2021 2:10 pm linkquote
A squared up indicator light would be handy
Weird to move when it's locked at an angle
There isn't much mechanical play in the front, when locked it rocks back n forth on the air in the tires, which aren't really very far apart for the amount of weight
Long & narrow only 3 wheels. as a piece of equipment on wheels to be pushed around it's made for flat & hard
I'm sure letting the suspension work while locked is an improvement...
Maneuvering at low speeds the wheels steer with less connection to lean, which can make it "feel wrong", causing me to lock up mentally just a bit, maybe take a dab or find my seat [reposition my body]
I don't brake while turning or going over bumps, the suspension works better, though I do ride around 2 fingers on the brakes most of the time
Perpendicular to earth light?
This would be good when locking the tilt on the road at a light
Fri Oct 08, 2021 1:56 pm
2008 fuoco
2008 fuoco
Fri Oct 08, 2021 1:56 pm linkquote
Got to sit on a brand new 750 forza this morning at the not to local Honda dealers. They were supposed to have a demo one but due to covid it never arrived.
imadequavers wrote:
Me too!
  DoubleGood Vespa Design
[ Time: 0.0361s ][ Queries: 5 (0.0170s) ][ Debug on ][ 209 ][ Thing One ]
