@ghiros avatar
'80 P200E
@ghiros avatar
'80 P200E
My main issue right now is that on my 1980 P200E the battery isn't charging (and hasn't since I bought the scoot).
I am pretty sure that the regulator is the problem (stator Ohm readings are good, but no voltage at the battery cables with engine running).
But it looks like the wiring overall isn't quite right.
The connectors on the pink, as well as the white&blue/purple cables look melted, but to me it seems more like a glue-gun job.
The cabling is also funky in the head (2nd pic). There are two combined white cables that are not currently connected, but I have no idea where they go or what they do.
My question is - would I get away with replacing the regulator or would it make sense to replace the wiring harness? Thoughts?
Thanks!
Arrow points to two combined cables that are not attached
Your wires look pretty good, so it probably be worth your time to find the right wiring plan - Scooterhelp.com can help with this. Running a new wiring loom in a P series is slow death - don't do it if you don't absolutely have to.
@rowdyc avatar
@rowdyc avatar
I would not get a new wiring loom but the fix will take some time. Will need to know/learn how to read a wiring diagram, how use a multi-meter, and how to add connectors on wires. If you think adding a new loom is easier, go that route.
The wires under the headset are janky at best but very fixable. Did you notice the blue twist wire connector that's not made for outside electrical use. That's not right. That blue wire is for the front brake switch but has an extra wire connected to the key switch. The disconnected white wires are from the front brake switch too. Don't need those wires but should connect correctly. There's other wire in there that's questionable, too.
The battery side is jacked up, too. That regulator is wrong and you will need this. https://www.scootermercato.com/Scooter-Parts/Regulators/160767_2 The wires you mentioned have been modified and need correction to work properly. There's other wire in there that's questionable, too.
If you decide to fix it, we can walk you through the process by using this diagram http://www.scooterhelp.com/electrics/wiring/VSX1T.USA.before.pdf
@ghiros avatar
'80 P200E
@ghiros avatar
'80 P200E
Thank you, guys! That sounds promising and like fixing is the way to go then.
I'm pretty much a novice - especially when it comes to electricity. Willing to learn, though, and I'd like to think I can follow instructions.
rowdyc, what you are saying about the cables for the the brake switch makes sense, because I actually don't have one. I assume it was removed when SIP adjustable sport levers were installed.
Thanks for pointing me to the right regulator! Regarding the diagram - are you saying I would use the 'before 1979' one, because I have two yellow stator cables?
Oh, and there are also some other things going on with the head: right now my turn signal indicator is always on, but the lo/hi beam one doesn't work at all. And he speedo illumination doesn't work, as well as the neutral light. All of that is really secondary, as it doesn't interfere much with riding.
How would I go about starting to fix all this then?
@rowdyc avatar
@rowdyc avatar
I would start by unplugging each component in the headset, junction box and battery side and try to identify each wire in the wiring harness. Take pics too. For whatever reason, things have been changed and before correcting, knowing what wires are what is a start. Will need a multimeter after disconnecting the components. Using continuity and the diagram can help to tell which wires are what and where they go.
An uneducated guess is the wires were changed due to a bad green wire and other wires were used as a kill switch wire. Also, someone may have tried to adapt that incorrect regulator to work with the bike's wiring harness. Just a guess though.
@safis avatar
@safis avatar
Regulator is correct according to the diagram. Double Gs for yellow wires, pink goes to B+, purple / white to C and it needs the ground / black wire connected. Kokusan regulators are crap, try to find a Ducati one…
@rowdyc avatar
@rowdyc avatar
I've never seen those regulator work with North America early P200's with double yellow wire stators. To my knowledge, the double yellow regulator is no longer in production by Ducati. I don't think those regulators flow/setup like the original regulators as seen in this schematic.
http://www.vespamaintenance.com/elec/charger/index.html
There are substitutes but not from Ducati .
https://www.scooterwest.com/p-regulator-for-1977-1979-p125x-p200e-218060.html
https://www.scooterworks.com/12-Volt-4-Pole-Rectifier-P2343.aspx
@safis avatar
@safis avatar
It's really strange that it doesn't work though. I have retrofitted the same regulator on my P that had no battery and it works exactly how your link describes. Gs are basically AC input / AC regulated output, B+ goes to battery and C gets the 12V DC "sense" from main switch when in ON position. Anyways, surely your market's Ps are way different from ours and parts although identical, are probably different…
@ghiros avatar
'80 P200E
@ghiros avatar
'80 P200E
rowdyc - sounds good. I hope I'll have time to sort out the cables soon.
@all - so which regulator should I get then?
@pheasant_plucker avatar
bare metal cafe racer
Is that not an aftermarket loom anyway? Looks way to tidy for a 1980 bike and has very tidy looking labels on the wires?
I'd be sitting down with a wiring diagram and multimeter and checking everything.
[ Time: 0.0296s ][ Queries: 6 (0.0072s) ][ Debug on ][ 313 ][ Thing One ]
