Mon Sep 06, 2021 7:24 pm
2010 Piaggio 250 MP3
Mon Sep 06, 2021 7:24 pm linkquote
Hello everyone I'm having some issues with my MP3.
VIN number is : ZAPM479M9A5004040
About a year ago I went for a cruise up the mountain about 4000 FT in elevation. I stopped, put gas in, walked around the mini-mart, came back out and the bike would not start again and called for a tow truck. While waiting for about an hour I tried starting the bike again, one time it started and died immediately and after it was put on the tow truck it started and ran for about a minute or two. the next day I fired up the bike and it ran fine for about a year. Although once in a while when I rode I noticed it would stop about as fast as a blink of an eye But would continue to run just fine. Once in a while, while stopping at a red light and idling for a few minutes it would die, like the idle set too low but normally starts right back up. the other day as I was going to put fuel in it died at the stop sign but restarted immediately after I put fuel in on my way back home a few miles it stopped for as long as of blink of an eye but continue to run just fine until I came to a stop the bike died and I have not been able to restart it for several days.
When I turn the key on I can hear a solenoid engage but I don't know if I can hear the fuel pump. If I take out the spark plug and add a little bit of gas down the hole and put the spark plug back in it fires right up.
Also when it did start it would run really rough And gutless until it warmed up
Mon Sep 06, 2021 10:25 pm
50cc Beo, MP3 400 2012, BigBeo 2003
Mon Sep 06, 2021 10:25 pm linkquote
Sound of fuel pump is missing. Which can mean that you need a new relay
Tue Sep 07, 2021 11:20 am
Tue Sep 07, 2021 11:20 am linkquote
ok thanks ill check it
Tue Sep 07, 2021 11:21 am
Tue Sep 07, 2021 11:21 am linkquote
I checked the fuses by the foot panel and the ones by the battery but I could not locate the the starter relay, i heard there was some there. I also swapped around the four relays under the windscreen and then I tried direct power to the fuel pump, I think. still no fuel.
Tue Sep 07, 2021 1:17 pm
2015 MP3 500 ie Business
Tue Sep 07, 2021 1:17 pm linkquote
If you're not getting the fuel pump to run when wired directly off the battery then the fuel pump is dead.
By the way, pic show pretty badly rusted battery connections.
Better clean that up. It is a Italian vehicle after all, the masters of electrical failures
Tue Sep 07, 2021 3:23 pm
Tue Sep 07, 2021 3:23 pm linkquote
Awesome, thank you for your input I appreciate it
Tue Sep 07, 2021 3:25 pm
Moderatus Rana
MP3 250 and 2 MP3 500s
Moderatus Rana
Tue Sep 07, 2021 3:25 pm linkquote
Is your evap system still installed?
Tue Sep 07, 2021 3:31 pm
Tue Sep 07, 2021 3:31 pm linkquote
yes it looks like it is still there.
Wed Sep 08, 2021 8:45 am
Wed Sep 08, 2021 8:45 am linkquote
Are you suggesting that could be the problem and I need to remove it? Thank you
Wed Sep 08, 2021 10:35 am
Moderatus Rana
Moderatus Rana
Wed Sep 08, 2021 10:35 am linkquote
Yes it could be. Either a compromised charcoal filter or a sticking rollover valve. The latter happened on my 250. Since the system is terribly engineered and doesn't really do anything I would remove it. At least you will have eliminated a cause and you get a little extra room in the boot.
Here is a wiki article I wrote back then on removal.
MP3 250: Removal of the evap canister and roll over valve
Wed Sep 08, 2021 10:44 am
Wed Sep 08, 2021 10:44 am linkquote
Understood, I'm on it.
very nice how to, thank you
Wed Sep 08, 2021 11:06 am
Moderatus Rana
Moderatus Rana
Wed Sep 08, 2021 11:06 am linkquote
Hope it helps.
Wed Sep 08, 2021 1:26 pm
Wed Sep 08, 2021 1:26 pm linkquote
Removed the evap system still no dice. what plastic panel do I start with to get to the fuel pump
Thu Sep 09, 2021 10:01 am
Moderatus Rana
Moderatus Rana
Thu Sep 09, 2021 10:01 am linkquote
Too bad. Worth a shot. At least you ruled that out. I am going to defer your fuel pump question to someone that has done it before on a 250. Good luck.
  DoubleGood Vespa Design
[ Time: 0.0282s ][ Queries: 5 (0.0074s) ][ Debug on ][ 209 ][ Thing One ]
