1968 VBB150
1968 VBB150
Hi All!
Can the lights/switched be tested with a battery pack on scoots with no battery? (ac or dc) If so, how? It would be nice to not have to have the engine running while troubleshooting.
Thanks!
⚠️ Last edited by dsnyder586 on UTC; edited 1 time
@scooterist avatar
@scooterist avatar
To some extend you can test a lot of the electrical components without having the engine running. I don't know what model of vespa you have but I tested horns, turn signals, headlights with battery and a power supply. I also tested stuff with a dmm and a test light, mainly continuity.
It depends what you want to test, if you want to do DC then a battery or battery packs will do it, for AC current You would want the stator spinning but again you can also test other stuff on the stator without power. What are you trying to do exactly?
The switches can be tested with minimal voltage, you can also test for continuity. The lights can be tested as long as you can satisfy the current to lit up. They might lit too dim if you don't have the right amount of voltage/current.
I test my stuff with a bench power supply, battery, DMM and a test light. You don't need all of them but it it nice to have.
1968 VBB150
1968 VBB150
Thanks!
180ss no battery (AC)
I was thinking of hooking up a 6v battery pack to the lighting circuit and making sure everything works. I just need ANY light, I don't need them to be bright for the testing.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
dsnyder586 wrote:
Thanks!
This works. I use one of those big 6V lantern batteries. Disconnect the wires from the stator at the junction box. It's not a good idea to send DC voltage back through the stator coils.
1968 VBB150
1968 VBB150
Perfect- thank you SOCAL!
@scooterist avatar
@scooterist avatar
What socalguy said. The 6V battery source would do it. Do you have access to the diagrams? look on scooter help.com.
That's a cool idea.
[ Time: 0.0205s ][ Queries: 3 (0.0014s) ][ Debug on ][ 313 ][ Thing One ]
