In your tool bag you'll need two 50mm (2 inch) square blocks of wood. Place the bike up on the centre stand. Rock the bike sideways and place one block under the foot of the stand. Then do this for the other side too. These blocks of wood will allow you to raise the rear wheel higher off the ground, usually around 6 to 8 cm. And this is just enough to slip the wheel off and on again without too much struggle.
A scooter jack isn't really necessary. You can usually find some rocks or scrap wood to lift up the rear of the bike. I was lucky today as there were a couple of old wood posts nearby. Whatever you use, just make sure that it's solid and won't collapse with some slight rocking motion.
The rest of the procedure is straight forward. Remove the nuts and washers, remove the wheel, put on the spare, and put the nuts back on.
50mm (2 inch) wood block under centre stand foot
Use scrap wood, bricks, or rocks to lift the rear wheel
Blocks allow you to lift the wheel higher off the ground
A puncture this size can cause the bike to become dangerously unstable and require an emergency stop.
Remove the 5 nuts and then the wheel by sliding it back and sideways.
Mount the spare wheel and finger tighten the 5 nuts. Tighten the nuts with a wrench in a crisscross pattern.
Finish up the job and then continue on to your favourite pub for a cold pint.
