@kiltman avatar
2005 ET4. Silver 2005 ET4 Red 2002 Honda ST1100ABSII
@kiltman avatar
I've had to replace the hinge on my ET4 seat. I also want to make a new seat cover. How do you remove the seat lock retaining ring? It doesn't want to pop out.
[img][/img]
I pressed mine out until it met resistance, and found a plastic tab hiding near the seat pan. I nudged it up with a tool while pressing the sleeve free. A bit of wd40 helps.
@kiltman avatar
@kiltman avatar
Thank you I shall give that a try
PS,
While restapling, my cheap Arrow stapler worked well IF the seat pan was well-supported and the stapler held firmly against the pan. Otherwise staples don't go fully home,.
@kiltman avatar
@kiltman avatar
Topolino wrote:
PS,
I'm not so lucky. With my other saddles I had better luck with a self tapping machine screw with a built in washer. I may go that route. Thanks for your advice.
[ Time: 0.0204s ][ Queries: 4 (0.0018s) ][ Debug on ][ 313 ][ Thing One ]
