Thu Nov 25, 2021 10:43 am
Piaggio mp3 300 yourban
Thu Nov 25, 2021 10:43 am linkquote
Hi guys, new to this forum. Basically I have done my front brake pads, then change some fluids in system cause they have been really dirty and bike won't start after that. Basically you press starter motor button and nothing after. No clicks no other noises, starter motor works fine when you click relay manually but looks like ignition is blocked and there is no spark. Any help would be appreciated.
Thank you
Thu Nov 25, 2021 10:53 am
Thu Nov 25, 2021 10:53 am linkquote
Could the brake light switches on the brake levers have come disconnected? Does the brake light come on when you squeeze either lever?
Thu Nov 25, 2021 11:01 am
Thu Nov 25, 2021 11:01 am linkquote
Thanks for replying. Yes both working. It's 2013 model which side brake I originally should be pressing?
Thu Nov 25, 2021 11:18 am
2006 GT200L "Lone Star"-Sold, 2006 Yamaha Majesty YP400(Sold), 2005 Genuine Stella 150 2T "Smoky"(Sold).
Thu Nov 25, 2021 11:18 am linkquote
Kill Switch set to "Run"?
I only ask because I've accidentally clicked mine off more than once after raising the seat at a gas station.
Good Luck!
Thu Nov 25, 2021 11:25 am
Thu Nov 25, 2021 11:25 am linkquote
Either side.
Thu Nov 25, 2021 12:00 pm
Thu Nov 25, 2021 12:00 pm linkquote
Kill swich done hundreds times. Unless there is somehow decided to go dead. I heard about some relays under the seat which would cut off ignition?
Fri Nov 26, 2021 4:52 am
mp3 500 2018 (USA-version)
Fri Nov 26, 2021 4:52 am linkquote
Does the key see the immobilizer?
Look carefully at all those places where your hands climbed. Maybe the problem is there .....
P.S.And hello neighbor
[ Time: 0.0262s ][ Queries: 6 (0.0071s) ][ Debug on ][ 209 ][ Thing One ]
