Thu Sep 30, 2021 9:55 am
2008 MP3 400
2008 MP3 400
Thu Sep 30, 2021 9:55 am linkquote
Tilt lock is not functioning properly; reservoir is full; horn beeps 5 times when engaged.
Previously had oil leak on ground which has since stopped.
Bike stays upright but can be leaned left and right when locked.
Dealer suggested issue(s): The leak will be either the tilt lock sensor or the hydraulic master cylinder.
How do I locate and access these or should this be a dealer fix?
Also exactly what mechanism happens when the tilt lock is engaged?
Thu Sep 30, 2021 11:20 am
Moderatus Rana
MP3 250 (sold) MP3 500 (current)
Moderatus Rana
Thu Sep 30, 2021 11:20 am linkquote
First check your battery. MP3's are very sensitive to voltage
The tilt lock is actually two mechanisms. Hydraulic to locks the shocks and mechanical to lock the tilt linkage. Sounds like your hydraulic system has issues since it is staying upright but getting squishy. Check the fluid level. It is just brake fluid. Sometimes topping it off will allow it to work again for awhile anyway. The bad news is you have to take off all of the front plastics to get to it to work on. If you have a good shop nearby I would just take it there.
Here are the beep codes
Thu Sep 30, 2021 12:01 pm
2013 MP3 300ie
2013 MP3 300ie
Thu Sep 30, 2021 12:01 pm linkquote
You can also just pull the horn relay from its socket, empty the reservoir (and/or remove the "rods" from the shocks), and call it a day.
I disabled the hydraulic part of the tilt lock system on my mp3 a few months ago because it was starting to fail just like yours (different cause probably, but same symptoms anyway).
Read: https://modernvespa.com/forum/topic175187
Can't say I regret that easy fix. I even like it better this way
  DoubleGood Vespa Design
[ Time: 0.0238s ][ Queries: 5 (0.0052s) ][ Debug on ][ 209 ][ Thing One ]
