First-time poster, not-so-long-time lurker...
I recently acquired my first scooter, a 1965 VNB6 (ODO ~5600), a failed restoration. The paint and bodywork were completed, but the engine, wiring, etc., were left as is. My wife was excited after the purchase and stated she wants us to be able to ride together on it and, if she likes it, to get a second scooter. If that isn't a stamp of approval to upgrade the 125cc to a 177cc while adding a few bells and whistles, I don't know what is.
Overall goal:
I want something that is reliable for traveling up and down the steep hills of the mountain west, can get me to and from work (2.4 miles each way), and the occasional tooling around town with my wife on the back to run quick errands/get coffee. Also, if it just so happens that the scooter could make it to the 60/8 club, I wouldn't be upset one bit.
The current state of things:
The engine was rust seized, and the stator plate looks water damaged. Based on opening the engine, I would guess I am the first to do so as all the seals were original and no tool marks to be found on the case or elsewhere. I didn't find any other indications of water in the case or damage from running the engine lean/internal component failure. Opening the engine made me a bit giddy to do a complete rebuild because why not extend this project over the entire winter and blow up the budget as soon as possible.
I am hoping people can provide a newbie some guidance before I go buying the wrong things. I have tried to do my homework a bit by reviewing engine rebuilds shared by others. However, I am stuck in the analysis paralysis phase since some are a few years old or missing exact part details.
What I would like to do:
1. Replace all seals, bearings, etc., with a rebuild kit (https://www.scootermercato.com/REBUILDKIT-VNBLATE).
2. Upgrade the cylinder to a 177cc - I have access to a Malossi 3-port 177cc cylinder and piston (https://www.scootermercato.com/Scooter-Parts/Cylinders/M-3117676_2). Is this useable as a "bolt-on" despite being 3-port? Most others I have seen have gone with a 2-port Pinasco (https://www.scootermercato.com/25030804).
3. Crankshaft - Is this something I should also be replacing? The stock on looks good but I have seen others substitute theirs out. Opinion's here would be greatly appreciated.
4. Switch to Electronic ignition - Thinking of going with the Vape Road (https://www.sip-scootershop.com/en/product/ignition-sip-performance-by-vape-road_510061RA).
5. Replace damaged wiring loom - SIP wire loom (would skip adding bar end indicators) (https://www.sip-scootershop.com/en/product/wiring-loom-sip-conversion-to-e-ignition-ducati-sip-performance-vape-ac_86135257).
6. Switch to Dell'orto/Spaco SI 24/24 E carborator (https://www.sip-scootershop.com/en/product/carburettor-dell-orto-spaco-si-2424e_40000000). I saw this got rid of some issues with qasooter's VNB5 rebuild.
7. Upgrade exhaust. I am a bit torn here between a Piaggio exhaust with catalyzer (https://www.sip-scootershop.com/en/product/exhaust-piaggio_PI4723R5) or a SIP Road 150 (https://www.scootermercato.com/SIPROAD-150). Is the Piaggio exhaust with catalyzer that much better for the environment? If it is better for the environment and won't dramatically impact performance, I am all for it. If it would make above performance modifications significantly weaker, then not so much due to the limited number of miles the scoot would travel in any given day.
8. Switch out the cable set - Do folks have opinions on the difference between Performace cable sets and standard?
Thank you, scooter hivemind, for your time and for helping out! As things move forward, I am happy to post pictures of the progression.
