Sat Oct 02, 2021 4:05 pm
Gilera Fuoco 500ie
Gilera Fuoco 500ie
Sat Oct 02, 2021 4:05 pm linkquote
Hello, can anybody shed some light on where this earth wire should go to. Gilera Fuoco 500 left side inspection hole near the spark plugs, the wire arrowed goes to nothing and has an eyelet n the circled end mounted to a fixing with another, I assume earth wire.
Loose wire arrowed
Tue Oct 05, 2021 4:22 pm
Gilera Fuoco 500ie
Gilera Fuoco 500ie
Tue Oct 05, 2021 4:22 pm linkquote
If anyone can help I would appreciate it. I have includded some more pics traken through the top instection hole under the seat.If someone could have a look at there bikes and see where the wire goes to It would be a great help.
Tue Oct 05, 2021 11:56 pm
2008 fuoco
2008 fuoco
Tue Oct 05, 2021 11:56 pm linkquote
I'll have a look later today and get back to you.
Wed Oct 06, 2021 12:25 pm
2008 fuoco
2008 fuoco
Wed Oct 06, 2021 12:25 pm linkquote
I had a look and can see where its bolted to the frame tube where you have circled it in your photo it then go's upwards disappering towards the front of the bike. I'll have another look tomorrow with my inspection camera that i forgot i had
Wed Oct 06, 2021 12:50 pm
Gilera Fuoco 500ie
Gilera Fuoco 500ie
Wed Oct 06, 2021 12:50 pm linkquote
Thank you mate,, I appreciate your help.
Thu Oct 07, 2021 9:27 am
2008 fuoco
2008 fuoco
Thu Oct 07, 2021 9:27 am linkquote
I removed the cover on the opposite side to the spark plug side and sent the camera probe in all i can say is that it's going towards the fuel cap. I even put my hand in to feel where it was going and nearly got my hand stuck in. All i can say is if everything is working as it should then leave it but if your realy concerned then your going to have to remove a lot of the tupperware and thats not a quick job .I've had mine off 3 times and even if i did it again tomorrow i'd still be scratching my head wondering which screws to remove and trying to find the hidden screws.
Thu Oct 07, 2021 10:23 am
2015 MP3 500 ie Business
Thu Oct 07, 2021 10:23 am linkquote
If it ain't broke, don't fix it.
Let sleeping dogs lie. No need to stir up electrical gremlins. It is a Italian vehicle after all.
Thu Oct 07, 2021 1:20 pm
Gilera Fuoco 500ie
Gilera Fuoco 500ie
Thu Oct 07, 2021 1:20 pm linkquote
It's bugging me,,, at least you've given me a general direction to look for the other end of the broken wire,,,,, thanks for looking I appreciate it.
Fri Oct 08, 2021 2:00 pm
2008 fuoco
2008 fuoco
Fri Oct 08, 2021 2:00 pm linkquote
Your only going to find where it is from by removeing the tupperware and i you will find it frustratingly time consuming .
Fri Oct 08, 2021 6:32 pm
Gilera Fuoco 500ie
Gilera Fuoco 500ie
Fri Oct 08, 2021 6:32 pm linkquote
yeh, done that, well most of the plastic seat tub etc,,, still cannot see the other end of the broken wire,,, well miffed with it so I am. Recently bought the Fuoco and found that mice had made a home under the plastic at some stage in its life,,, chewed the wires behind the clocks,, on top of the fuel tank and had a go at the wiring harness on the frame just above the spark plugs,,, maybe they eat the other end of the broken wire Ha Ha that's why I Carnot find it.
Sat Oct 09, 2021 11:41 pm
2008 fuoco
2008 fuoco
Sat Oct 09, 2021 11:41 pm linkquote
May be it's a single wire that is spur coming out of a wrapped part of the wiring,look for the mice nibbled loom and unwrap the tape.
Sun Oct 10, 2021 12:28 am
Gilera Fuoco 500ie
Gilera Fuoco 500ie
Sun Oct 10, 2021 12:28 am linkquote
My last post was a little light hearted,,, the loose wire does not reach the area that the mice have been too. Eventually took you advise and left it as all appears to be working,,, all back together now.
  DoubleGood Vespa Design
[ Time: 0.0351s ][ Queries: 7 (0.0144s) ][ Debug on ][ 209 ][ Thing One ]
