railfancwb wrote:
Just noticed my 1980 P200e suddenly doesn't totally release in 1st gear. Even with the clutch lever pulled it still wants to creep. Shifting from 1st to neutral is also difficult.
I think the transmission oil may be low so I plan to drain and refill. Could low transmission oil cause the first gear issue?
If changing transmission oil doesn't resolve the issue should step two be clutch cable adjustment?
If it still isn't resolved should shifter cable adjustment be step three?
Thanks.
I'd check for clutch cable tension first.
At the clutch lever, you need about a 2mm gap (at the point closest the headlight) from the lever resting position, until you feel spring tension.
Any looser than that you won't be able to engage the gears properly.
If for any reason you can't achieve the 2mm free play, the cable probably needs swapping out or the springs or the plates.
FINYoshi I didn't know this till about a few years ago, but the clutch has 1 wavy plate (it has a notch in it) and it's suppose to help free the plates when the lever is pulled. I was always under the impression they all had to be straight.
