@medicineman avatar
Vespa 2006 gt 200
@medicineman avatar
Vespa 2006 gt 200
I installed a new battery and still nothing when I hit electric start. Ideas?
@vintage_red_matthew avatar
MV Santa
MV Santa
Kill switch.
Brake light switches. Check the brake lights.
@everytimeidom avatar
2003 ET2 (SOLD); 2004 GT200
Missing some context here. Why did you replace the battery? Did you test your old battery before replacement to confirm it was the problem? When you say "still nothing" does that mean no headlight/lights on the cluster when the key is in the ON position or just no start?
@medicineman avatar
Vespa 2006 gt 200
@medicineman avatar
Vespa 2006 gt 200
Battery was low. Had headlight and display. Would dim when I press starter switch. But no click
@petercc avatar
Piaggio Beverly 300 ie - 2012
@petercc avatar
With the new battery, if you switch on the contact, do you then have normal display reading?
@berto avatar
@berto avatar
What about the immobilizer light? Is it off?
@garthhh avatar
@garthhh avatar
No click , no starter relay engagement
The two smaller pins on the relay need 12v & a ground to engage
@medicineman avatar
Vespa 2006 gt 200
@medicineman avatar
Vespa 2006 gt 200
Thanks all. I took the belt cover off and saw the starter gear and gotten stuck. Lubed it and put it all back together. Enjoyed a couple of nice rides today.
I'm really enjoying the scooter
[ Time: 0.0110s ][ Queries: 3 (0.0039s) ][ live ][ 313 ][ ThingOne ]
