@garncarz avatar
1964 Allstate Cruisaire, 2022 Husqvarna Vitpilen 401, 1972 Suzuki T500J
@garncarz avatar
I just replaced the 55 year old grips on my Allstate. I did a lot of research and watched videos using grip glue and an air compressor. Seemed like a lot of effort. So, I would like to propose a very easy yet very effective process:
1. Using a razor knife, cut the old grip down to handlebar and then all the way lengthwise.
2. Using a screw driver pry the old grip apart and remove.
3. Soak a small rag in acetone (acetone will instantly destroy any paint it touches) or WD40 and remove any old glue from the handle bar.
4. Go to your local golf or sporting good shop an buy one strip (12" length) of grip tape.
5. Apply the grip tape to the handle bars, tucking about 1/2" inside the hole at the end.
6. Apply a light coat of WD-40 to the tape. It should be very slippery now.
7. Slide the new grip on, with ease.
8. Bob's your uncle.
⚠️ Last edited by garncarz on UTC; edited 1 time
@scooterist avatar
@scooterist avatar
^^ Good method. I need to change a pair soon.
@chandlerman avatar
Lucky
45 Days Since Last Explosion
Lucky
@chandlerman avatar
I just put new "regular" rubber/vinyl grips on the GL to replace the craptastic SIP grips I put on a few months ago. I heated the grips with my heat gun on a lower setting to soften them, then sprayed everything with hairspray and it worked perfectly too.
Did the WD-40 not attack the adhesive in the grip tape?
@garncarz avatar
@garncarz avatar
WD-40 softens the glue but evaporates in about and hour and the glue becomes glue again.
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
Oh, nice! That makes a lot more sense now
Hair spray is all that's necessary. Grip tape could become a mess later on. Hairspray is good because it keeps the grip solid, but will break loose with an air gun.
[ Time: 0.0099s ][ Queries: 3 (0.0028s) ][ live ][ 313 ][ ThingOne ]
