@jcg avatar
2008 GT200L
@jcg avatar
2008 GT200L
I switched on my brights... the blue dash light displays the brights are ON... but the bright headlight is NOT on.
Is it the bulb? Why would the "dash board" display the "brights" are on when the bright bulb is not on?
I just replaced the perpetual daytime bulb.
Yep, check the bulb. Sometimes you get a wonky one.
@jcg avatar
2008 GT200L
@jcg avatar
2008 GT200L
I had recently changed the left bulb due to not having any bulb eluminate with low beam ON I Had high beam only...
Now the bulb on the right never eliminates...whether High or Low beams are on. Bulb on left turns off when HIGH beam is turned on. Which bulb is the problem?
so the opposite is happening now. I have Low but no High
If explanation is vague, Here is video
[ Time: 0.0106s ][ Queries: 4 (0.0042s) ][ live ][ 339 ][ ThingOne ]
