'81 Vespa P200e, '85 Vespa PX125e, 1985 T5
Hey All,
Just wondering if someone can walk me through the steps of gasket matching a 24mm carb to the 20mm air box?
Looking for detailed steps and visuals (if possible) on how to perform this modification correctly.
This may be a final ace in dialing in my scoot.
Looking forward to learning more.
Thank you.
N
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
There's not too much to it.
As you can see from the pic, the openings between the carb, carb box and inlet are a bit different as they come from the factory.
The object is to match the openings and create an unobstructed flow of the air-fuel mixture from the carb into the crankcase.
Start by marking the openings. Using a rotary tool and sanding wheel *carefully* grind the box to match the carb. Be *extra careful* grinding the opening on the case, because if you take off too much material you'll ruin the sealing surface and introduce an air leak.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
on the case side you can blend at the top and let the lower part of the opening remain untouched. if you start to go too nuts you will hit the stud opening on the back side. It's easiest done with the engine split, of course, otherwise hard to keep material from entering the engine and trashing your bearings, etc.
@chandlerman avatar
Lucky
48 Days Since Last Explosion
Lucky
@chandlerman avatar
Also, if you have the cases split, you can trace/score the base of the carb into the airbox, then bolt the airbox to the case and do the whole thing as a single unit to get the matching really nice.
@scooterist avatar
@scooterist avatar
I have done it once or twice. I did a 26mm carb in one of the P and a 24 mm on another P. It was fairly easy from what I remember, just remove the carb box, enlarge the gasket and also enlarge the intake reed.
It is your choice of using a file or a dremel, the end result is the same, just make sure you stuff a small rag inside the engine case reed and vacuum it of blow it after you are done. in reality there is no mystery to it. As long as the engine case opening is at least the diameter of the carburator Venturi you are good to go, if the engine case reed opening is smaller than the Venturi of the carburator then you accomplished nothing. Good luck!
Thanks everyone.
As opposed to dremmeling and matching, would an alternative be to simply purchase a carb box for a p2 and mount that on my 125 cases?
Thanks for all of your helpful responses.
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
Not necessarily. Even with the 24mm carb box on my P200 motor, I had to do a moderate amount of port matching to open it up.
The ideal way to do it is with a Dremel or other rotary tool. Start with grinding bits, then move to sanding drums once you get close.
The bits & drums are cheap. I get mine off Amazon for maybe $10/set and they last damn near forever, it seems like.
[ Time: 0.0129s ][ Queries: 4 (0.0050s) ][ live ][ 313 ][ ThingOne ]
