Vespa Et4 150
Vespa Et4 150
Can anybody help? I just put on a new drive belt and variator. My Vespa still won't start. Does anyone have any idea what it could be?
@grahamlml avatar
Vespa GTS 250 , Baotian 70cc rat scooter, Yamaha V50M 1979
@grahamlml avatar
Is your small earth wire at front edge of the transmission case attached ok and not loose, had this happen to mine as bolt was a fraction to long and left the earth cable very slightly loose so it wouldn't make good contact also the frame bolt check and clean cable ends if not already done so.
Hope that helps.
Vespa Et4 150
Vespa Et4 150
Thanks it's so weird it was running fine but belt broke replaced it now it turns over but it will not start I can't figure it out
@rickster333 avatar
2001 ET4 "Mona"
@rickster333 avatar
2001 ET4 "Mona"
Kill switch?
@rickster333 avatar
2001 ET4 "Mona"
@rickster333 avatar
2001 ET4 "Mona"
Wait...That's stupid on my part. If it turns over it isn't the kill switch. Sorry.
@juan_orhea avatar
S150 '09, Beo 500ie '08
@juan_orhea avatar
Edit: I retract the part about the kill switch, but not the part that Rickster333 is not stupid. Hopefully the triple negative is crystal clear here.
⚠️ Last edited by Juan_ORhea on UTC; edited 2 times
Vespa Et4 150
Vespa Et4 150
Thanks guys it's not the kill switch still tryin to figure it out
@greasy125 avatar
@greasy125 avatar
Juan_ORhea wrote:
No, not stupid. The kill switch only kills the spark. The engine will turn over all day with the kill switch off.
not on an ET4 it won't
@greasy125 avatar
@greasy125 avatar
sounds like you assembled something incorrectly or knocked something loose.
did you drop the engine down or lift the body to do the belt?
besides the belt, did you do anything else in the process of replacing or any other repairs?
[ Time: 0.0133s ][ Queries: 3 (0.0039s) ][ live ][ 339 ][ ThingOne ]
