@miguel avatar
@miguel avatar
Nope! At least the Loctite 51001 C5-A Copper Based Anti-Seize isn't.
I thought it might be given the name and color. I didn't really need to know this for any reason today but I was using it to assemble an outdoor umbrella that I thought someday I'm going to want to disassemble and replace. I measured the resistance of the anti seize while I had the anti seize out and in hand. The probes were about 2mm apart in a glob of anti-seize and the meter was set to the 2 Meg-ohm scale. .
Best
Miguel
@tor2ga avatar
@tor2ga avatar
That's useful info. Thanks.
I kinda find this hard to believe as most everything I have read about anti-seize paste is that they are conductive. And the type you use relates to how much heat it would be subject to.
[ Time: 0.0097s ][ Queries: 3 (0.0031s) ][ live ][ 313 ][ ThingOne ]
