2008 MP3 250
2008 MP3 250
Where is the fuel pump relay on a 08 250. I searched everywhere in the service manual to no avail. Second question is would my fuel pump replacement still be covered under that recall this many years past. Now that it's getting cool here in North Florida it's time to get on this repair.
2015 MP3 500 ie Business
IIRC, that was a recall issued by Piaggio and filed with the NHTSA.
So as long as the recall was not performed prior, and you don't have a oddball case (such as a imported Euro spec model), the recall should still apply.
2008 MP3 250
2008 MP3 250
So nobody knows where the fuel pump relay is?
@jah avatar
Piaggio MP3 250'2007
@jah avatar
Isn't it one of the four under front fairing?
2008 MP3 250
2008 MP3 250
Thanks Jah, you're the first to respond with an answer. I'll check there but now I really need to take that fairing off. Was putting it off as long as I could.
@spdtwn avatar
Honda PCX 160. Kymco Like 200. Piaggio Zip 100.
@spdtwn avatar
It's just the screen and the cover off to check the relays.
I optimistically hoped that it was the relay on my 250,'cos the alternative was a floor full of plastic bits. It was the fuel pump. Piaggio's build method, I soon found out. was to put the engine and fuel tank in first and then assemble screeds of plastic around it...with different screws just to make things interesting.
One good point was finding a pump supplier (in USA) that was a quarter of the cost of OEM.
Great fuel pressure now.
Good luck.
2008 MP3 250
2008 MP3 250
Thanks guys I found the relays. With the front screen off and all relays in place I turned on the ignition and I got a steady beeeeeeeeeeep. There must be some type of switch in there telling the scooter the screen is off or something. Anyone had to deal with this?
@jah avatar
@jah avatar
No, there's no such thing. Constant beep is related to pressure failure in suspension lock.
[ Time: 0.0154s ][ Queries: 3 (0.0068s) ][ live ][ 339 ][ ThingOne ]
