Mon Nov 01, 2021 10:30 am
VNB vsc o9c VMA vbc VSX
Mon Nov 01, 2021 10:30 am linkquote
A thread devoted to that random turn of phrase, or comments that get your attention, make you laugh, or just seem worth noting...
(Hoping this thread can be evergreen. Feel free to use old gems and NSM-isms, from folks now long gone.)
I'll start... from Chandlerman on fire safety:
Chandlerman wrote:
I've set myself on fire enough for one lifetime.
Mon Nov 01, 2021 10:38 am
'15 GTS300, '86 PX125EFL, '66 VBB, '04 Ninja 250
Mon Nov 01, 2021 10:38 am linkquote
applicable this week:
90% of carb problems are electrical
Mon Nov 01, 2021 10:48 am
Mon Nov 01, 2021 10:48 am linkquote
Always pressure test an engine before you install it
Fit your floor rails before you paint
I think that's the last part for the order.... <send> ... OH NO!!
Mon Nov 01, 2021 11:02 am
1979 P150X, 1983 P200E, 1988 T5, 1995 PX200E, 2011 Yamaha Fazer 600 S2
Mon Nov 01, 2021 11:02 am linkquote
This one is mine...
Whoever designed the smallframe engine and decided to put the gear selector and cables where he did, he should have been hanged by the balls, at the central square of Pontedera...
Mon Nov 01, 2021 11:22 am
'07 GTS250ie "Mechanical Squirrel", '66 Honda Benly, '19 Suzuki 250 cafe "Mouse", '77 Jawa 350TS, '42 Henschel PzKw VI Tiger
Mon Nov 01, 2021 11:22 am linkquote
An old bike will always start first kick when you are alone in the garage. Said same machine will never start without a fight when at a rally with an audience.
Even though its a cool feature, never reverse your Russian army bike at a rally, you will dump it and flip your wife off onto the wet grass.
Always marry someone who shares your interests. That way when you fuck it up they are more likely to appreciate the situation in a more forgiving light and cut you some slack. ( see above dumping of the wife incident )
Mon Nov 01, 2021 11:49 am
Lucky
76 Sprint V, 63 GL, 62 VBB, 05 Stella, 66 Smallstate, 08 Stella (for now)
Lucky
Mon Nov 01, 2021 11:49 am linkquote
For better or worse, I do seem to live my life as a cautionary tale for others.
That being said, I'll go with a few thoughts on riding safety:
Dress for the crash, not the ride.
and
Without gloves, your fingers are just red crayons.
Luckily, I only learned the first one The Hard Way
Mon Nov 01, 2021 1:35 pm
'74 50s x3 '78 P200 E '84 Cosa '91 PK50XL2 '58 AllState '68 Sprint '80 50special and a '66(?) Super125
Mon Nov 01, 2021 1:35 pm linkquote
I'll play...
Torque flywheel nut well before testing kick starter!
also, see below, especially this part
Mon Nov 01, 2021 1:38 pm
VSX, Stella 177, Stella 150, VNX1T, V9A1T, V9B1T
Mon Nov 01, 2021 1:38 pm linkquote
V oodoo wrote:
I'll play...
Or my personal repeated mistake... Don't forget to remove the flywheel holding tool before trying to kickstart after making timing changes!
Mon Nov 01, 2021 1:42 pm
Mon Nov 01, 2021 1:42 pm linkquote
done that
Mon Nov 01, 2021 1:51 pm
Lucky
Lucky
Mon Nov 01, 2021 1:51 pm linkquote
sdjohn wrote:
done that
Ditto. Might even have done it pretty recently...
Mon Nov 01, 2021 2:56 pm
Mon Nov 01, 2021 2:56 pm linkquote
Dont forget the Cotter Pin
Mon Nov 01, 2021 3:05 pm
'70 Super 150, Aprilia SR MT 125, Moto Guzzi Bellagio
Mon Nov 01, 2021 3:05 pm linkquote
My main one would be: Engine cases are soft as cheese. Take your time and have patience when doing up bolts.
Mon Nov 01, 2021 3:36 pm
1968 VBB150
1968 VBB150
Mon Nov 01, 2021 3:36 pm linkquote
"If someone on NSM says Do it THIS way, and another person concurs, there is a VERY good reason"
Also, dry fit everything, ESPECIALLY Floor rails.
Mon Nov 01, 2021 3:40 pm
Mon Nov 01, 2021 3:40 pm linkquote
Always modify the cheapest part.
Mon Nov 01, 2021 3:56 pm
Mon Nov 01, 2021 3:56 pm linkquote
If the rear wheel locked up, it was a 'Hard Seize'.
Run-in is the time it takes to convince yourself it's not going to explode.
The number of running bikes can never exceed three.
Mon Nov 01, 2021 4:05 pm
Mon Nov 01, 2021 4:05 pm linkquote
straight gold.
Mon Nov 01, 2021 10:58 pm
Mon Nov 01, 2021 10:58 pm linkquote
V oodoo wrote:
I'll play...
Torque your kickstarter (or at least put the bolt & nut back in) before trying to kick start
Tue Nov 02, 2021 2:44 am
Tue Nov 02, 2021 2:44 am linkquote
"It ran when I parked it in the shed"
Meaning; I ran for bloody miles trying to get the damn thing started & finally made it to the shed.
"Only needs a minor tuneup & it will run"
Meaning; there was a time that I sprayed a bucketload of ether into the carb & put in a brand new plug & it fired, but possibly it's got no spark, electrics cannot be tested as it wont start, there is a chance it has low compression, but at times it seems very high, as almost seized...
Tue Nov 02, 2021 2:57 pm
Tue Nov 02, 2021 2:57 pm linkquote
More power?
Hey, cheap and easy!
Just bolt on this XXX kit, it's all Plug and Play!
But you might want to consider a decent GS piston now, just saying...
Oh yeah, likely wanna upjet a couple points while you're in there...
If you keep that shitty() stock carb...
And check your TIMING too, especially if you go fancy new proper ignition...
Well, yeah that crappy stock muff IS kinda holding you back now...
How are your brakes, shocks and tires?
Factory original, eh?
Nice...
Tue Nov 02, 2021 4:00 pm
Old douglas ..smallie with polini 115..super with nasco 177
Tue Nov 02, 2021 4:00 pm linkquote
chrome dont get ya home
Tue Nov 02, 2021 5:40 pm
1959 Allstate w PX Engine
Tue Nov 02, 2021 5:40 pm linkquote
V oodoo wrote:
More power?
Nice...
So true...
Buying a vintage Vespa is inviting someone over for Nail Broth.
Read here by Danny Kaye, ca 1960:
Tue Nov 02, 2021 8:21 pm
Evil
PX 200
Evil
PX 200
Tue Nov 02, 2021 8:21 pm linkquote
Need to get a tattoo of this quote
Evil
PX 200
Evil
PX 200
These are gold
Tue Nov 02, 2021 9:22 pm
Tue Nov 02, 2021 9:22 pm linkquote
"Grade AA - first-class repair" can somehow get lost with the German translation
Tue Nov 02, 2021 9:48 pm
Tue Nov 02, 2021 9:48 pm linkquote
Caused a good chuckle.
- Your new motor isn't seized. You forgot to take the rubber stopper out of the exhaust outlet.
- Don't forget the cotter pin...
Wed Nov 03, 2021 1:15 am
Evil
PX 200
Evil
PX 200
Wed Nov 03, 2021 1:15 am linkquote
"Its a 15mins job... will only take 10... (still at it after 4hours staring at the part/gasket/O ring which snapped)"
Wed Nov 03, 2021 5:54 am
Wed Nov 03, 2021 5:54 am linkquote
Along those lines, whatever money you've budgeted, multiply by two. For time, multiply by three.
Wed Nov 03, 2021 5:55 am
Wed Nov 03, 2021 5:55 am linkquote
A scooter is worth X
If it doesn't run, multiply by 1/2
If it's in pieces multiply by another 1/2
If it doesn't have a title, multiply by another 1/2
-Greasy
Wed Nov 03, 2021 6:23 am
Wed Nov 03, 2021 6:23 am linkquote
Not scooter related, but same formula for large IT projects: "ask three experts to estimate the project, add them together"
Wed Nov 03, 2021 6:44 am
2 - Many
2 - Many
Wed Nov 03, 2021 6:44 am linkquote
Femsatronic is a dirty word but not because of what civilians think it means.
Wed Nov 03, 2021 11:22 am
Lucky
Lucky
Wed Nov 03, 2021 11:22 am linkquote
For ERP projects, multiply instead of adding.
Wed Nov 03, 2021 11:46 am
Wed Nov 03, 2021 11:46 am linkquote
what is ERP?
Wed Nov 03, 2021 12:10 pm
Lucky
Lucky
Wed Nov 03, 2021 12:10 pm linkquote
sdjohn wrote:
what is ERP?
Enterprise Resource Planning systems...essentially, a combined accounting & operations management platform for a company. I've seen more than one ERP upgrade project run over budget by tens of millions of dollars. At one company I was at, it went 10x over budget ($8mm budgeted, $80mm actual). Multiple C-Level exec heads rolled before that mess was over.
Even worse, on that particular debacle, they didn't even come up with any new & innovative ways of screwing it up, they just made the worst possible choice every step of the way (with Accenture's Time & Materials billed help, of course)
Wed Nov 03, 2021 12:11 pm
1967 Granturismo 177, 1979 P200E, 1974 Primavera 125 Hooligans S/C Seattle/Austin
Wed Nov 03, 2021 12:11 pm linkquote
It's a meme but, still one of my all-time favorites.
Wed Nov 03, 2021 2:54 pm
Wed Nov 03, 2021 2:54 pm linkquote
___________
"It's not hard... when it's clean!!!!"
-Vader19
(RIP brother.)
Wed Nov 03, 2021 3:18 pm
'62 Allstate, '62 Vespa VBA
Wed Nov 03, 2021 3:18 pm linkquote
An old bike that starts the first kick will never start again.
I had this DKW 125 about 15 years ago. I did a marathon rebuild for a camping trip. My uncle was hauling a trailer, and I wanted to get it on the trailer before he left in the morning. 1:30 the night before, had everything buttoned up, put gas in it, gave it a kick. RINGADINGDINGDING!! Woke up the neighbors. Shut it down, and went to bed with a smile on my face. Next morning, NOTHING. It never ran again. Finally sold it a couple years ago.
Wed Nov 03, 2021 3:31 pm
Lucky
Lucky
Wed Nov 03, 2021 3:31 pm linkquote
Something just occurred to me. BN started this thread with something I had posted.
I just remembered that my daughter has had a group text going for several years now with what's become an absurd number of people that's called, "Shit my dad said," and is nothing more than her relaying stuff I've said to her friends.
I've also had my coworkers coin the term "Chandlerism" to refer to the stuff I (and apparently only I) have said not once, but twice, in the course of my career.
So I'm both pleased and infinitely amused that I've incidentally been the germination of this thread in yet another forum.
Nothing more to add, other than that I'm also told that I'm fun to have at parties.
Thu Nov 04, 2021 12:40 am
px 200, lxv 125
px 200, lxv 125
Thu Nov 04, 2021 12:40 am linkquote
OI! you are dealing with the wrong experts!
" It was only an hour job on the you tube video" (three days later)
Thu Nov 04, 2021 12:44 am
px 200, lxv 125
px 200, lxv 125
Thu Nov 04, 2021 12:44 am linkquote
fast, reliable, cheap, chose two of the three
Thu Nov 04, 2021 5:12 am
Thu Nov 04, 2021 5:12 am linkquote
A classic!
  DoubleGood Vespa Design
[ Time: 0.0453s ][ Queries: 7 (0.0229s) ][ Debug on ][ 211 ][ Thing One ]
