Hello. I currently have my P200E with the malossi 210 splitted open because I was replacing the kick start gear. Before I finish the engine I would like your help identifying what seems to be (I believe) a common discrepancy.
The engine hesitates hard only on second gear and third gear under heavy load. Imagine that you are accelerating and right in the middle of the acceleration imagine pulling the clutch lever in and reving the engine more and letting the clutch lever go again, kind of like "popping the clutch when you do a wheelie). In reality , the problem is not the engine, the engine pulls hard, it just something on the drivetrain causing it to yank.
The situation has been very annoying, unsafe and embarrassing. Annoying because the scooter jerks in the middle of the acceleration, unsafe because when I ride with my son under the acceleration the scooter yanks you back and then forward and embarrassing because I create often a situation where people on cars races me just because they think I am "racing" pulling the clutch.
English is not my first language so I don't know what words to use to best describe the situation. I googled it using my own words but I am not finding anything. I purchased a new cruciform(I haven't installed it yet). The gears go in just fine. Is the current cruciform not holding the gears on place?
I would like to get this situation resolved before closing the cases. Thanks a lot!
