Mon Nov 01, 2021 3:50 pm
Piaggio 2016 MP3 500
Mon Nov 01, 2021 3:50 pm linkquote
Is there a better seat to get for a 2016 MP3 500 than the stock seat and if so where?
Mon Nov 01, 2021 6:41 pm
2016 MP3 500 Sport
2016 MP3 500 Sport
Mon Nov 01, 2021 6:41 pm linkquote
I have the Piaggio gel saddle on my 2016 500 and I could not be happier. 100 miles on the stock saddle was torture, but I have done 400+ mile days on the gel with no discomfort.
Mon Nov 01, 2021 7:24 pm
Mon Nov 01, 2021 7:24 pm linkquote
Where did you get the gel saddle?
Mon Nov 01, 2021 7:29 pm
2016 MP3 500 Sport
2016 MP3 500 Sport
Mon Nov 01, 2021 7:29 pm linkquote
Online, but I don't remember where. They are available from several sites. Pricey, but I think worth it.
Mon Nov 01, 2021 7:30 pm
Mon Nov 01, 2021 7:30 pm linkquote
Thank you.
Mon Nov 01, 2021 11:54 pm
2015 MP3 500 ie Business
Mon Nov 01, 2021 11:54 pm linkquote
Vespa Motorsport sells the Piaggio gel saddle AFAIK.
I also use the same saddle and could not be happier, BUT IMO swapping out the rear shocks for some Bitubos gives a bigger return on investment. The stock rear shocks are simply put "utter garbage".
I use the Bitubos that were manufactured for and sold only by Piaggio.
Unfortunately, in Piaggio's continual lack of wisdom they have already discontinued the brown version of the gel saddle. Ditto on the bespoke version of the Bitubo shocks with oil reservoir.
Vespa Motorsport still has a brown gel saddle in stock, so get one while it lasts.
https://www.scooterwest.com/brown-comfort-gel-seat-piaggio-mp3-500-abs-seat-mp3500-brn-gel.html
Don't know if the black version has been axed as well.
Fri Nov 05, 2021 3:04 pm
MP3 500
MP3 500
Fri Nov 05, 2021 3:04 pm linkquote
Find a local upholstery shop willing to do motorcycle gel inserts if you supply the insert. There are numerous suppliers selling inserts, however I have settled on just one. Not only is it reasonably priced, it will not deform under pressure. However be forewarned that all gel seats will absorb and retain heat from direct sun light. https://shocktec.com/product/motorcycle-seat-insert-shocktec/
To minimize hot seat syndrome the attached product will help.
https://www.laminarlip.com/kwik/kkindex.htm
Last edited by Maynard Schweigert on Sat Nov 06, 2021 8:56 am; edited 2 times in total
Sat Nov 06, 2021 8:46 am
Sat Nov 06, 2021 8:46 am linkquote
The second link is the same as the first
MP3 500
MP3 500
Sat Nov 06, 2021 8:56 am linkquote
My Bad.
Tue Nov 09, 2021 11:55 am
2008 fuoco
2008 fuoco
Tue Nov 09, 2021 11:55 am linkquote
The original 2008 Fuoco saddle/seat that i have says it's a gel one but there hard and uncomfy and not helped by the riding position . Do what i did and modify it yourself until you get a seat form that your happy with then get it recovered by someone who recovers bike seats for a living and who cares about what there customer wants. Also i've tried a gel insert and i found with mine your bum doe's seem to get warm.
Tue Nov 09, 2021 5:07 pm
MP3 250 & Sei Giorni 300 HPE
Tue Nov 09, 2021 5:07 pm linkquote
Check out Airhawk. Had mine for 20k km . Wouldn't be without it.
No pressure on the bum bones
Here's A Revzilla review
  DoubleGood Vespa Design
[ Time: 0.0414s ][ Queries: 5 (0.0204s) ][ Debug on ][ 209 ][ Thing One ]
