2020 Vespa Sprint 150 Notte, 2007 Piaggio BV250
Hi,
I'm detecting some seepage from underneath my 8000 mile BV250 scooter that seems to be from the part seen in the photo. Basically, a small coin-sized leak is seen after the scooter has been sitting about 24 hours after its last ride. I'd like to replace the gasket from that connection near the exhaust outlet that has the two screws. I'm hoping that solves the problem without having to take the engine out and replace that major gasket in the background!
Oh, and I did replace the oil sump and gasket which solved a different leak but not this one.
Thanks in advance for any help you can provide.
What is this part?
What is this part?
@25bikez avatar
2022 Liberty 150S-"Meg"-SOLD
@25bikez avatar
mborkum wrote:
Hi,
That tube is part of the emissions system. There's nothing really to leak from it except exhaust.
I had a leak in my GT200 in exactly the same place. It turned out to be the cylinder base gasket (where the black and silver engine castings meet), which requires removing the engine, pulling the head and cylinder, and installing a new gasket once you clean up the mating surfaces. It's time consuming, but not difficult if you have space and tools.
Hopefully, it's not that, and someone with lots more experience can weigh in, but it looks awfully similar.
Ugh. Definitely not the answer I wanted to hear but I really appreciate the insight.
Given that the scope of the effort is beyond my comfort level I will have to take her to either a local scooter repair place or the nearest Vespa dealer for them to fix. Any ballpark figure for the cost of having an expert address a leak like this?
Some places are historically backed-up for repairs, so in the event that you couldn't get an appointment to get this fixed for several weeks (or over a month) would you leave the oil intact and place a bucket under her, or drain the oil to prevent further leaking?
Worst case, should I drain the oil for winter storage?
Thanks again!
@25bikez avatar
@25bikez avatar
Thanks again!
I can't advise you on repair costs, because I do almost all my own work, but it'll take several man hours (if that is indeed what is wrong). The gaskets, washers, o-rings, etc you need are fairly cheap. No real need to drain it at this point. The oil (or is it coolant, or both?) seep because they've been pumped up into the head during running and pressure/temperature force them out of what is probably a tiny leak until the engine cools and everything equalizes. If it were me, I'd put a disposable baking sheet or cake pan under it to catch the drips until you can get it repaired. If you run it, just keep an eye on the oil and coolant levels. Engines eventually leak. Go to any car or airplane show, and everybody has drip pans under their engines. Good luck.
@attila avatar
@attila avatar
A joke my friends and I play at classic vehicle rallies is to put a slick of oil under the engines that don't leak. The owner panic is a hoot!
The irony is as a former owner of an old Harley-Davidson one would think that I would be used to oil leaks by now...
@25bikez avatar
@25bikez avatar
ROFL emoticon
@25bikez avatar
@25bikez avatar
I've owned a couple of Sportsters. I feel ya.
[ Time: 0.0170s ][ Queries: 4 (0.0077s) ][ live ][ 313 ][ ThingOne ]
