LX150 ie
LX150 ie
Good day guys! I have this problem for my Vespa Lx150i3 2013 model. Please help me if you have encounter this problem. For short trips, my idle is ok and fine, the scooter runs perfectly but sometimes, if I ride it for a long time, the engine suddenly stops or die specially in stops , my idling will be abnormal. I will compensate it by throttling and braking in order to prevent it from dying.
I cleaned the throttle body and I adjusted my idling but still I have this same problem.
Hoping for your inputs.
Salamat!
@juan_orhea avatar
S150 '09, Beo 500ie '08
@juan_orhea avatar
These symptoms happened to me too. My problem: loose connection in the high tension wire between the coil and spark plug. In my case the spark plug side was easy to check. But the loose connection was on the coil side.
Took a long time to figure out! Hope this helps.
[ Time: 0.0105s ][ Queries: 3 (0.0033s) ][ live ][ 313 ][ ThingOne ]
