@garncarz avatar
1964 Allstate Cruisaire, 2022 Husqvarna Vitpilen 401, 1972 Suzuki T500J
@garncarz avatar
The '64 Allstate has a bellows tube that connects the carb airbox to the inside of the frame under the fuel tank. This space is is fairly well sealed up, from an airflow standpoint. How, from where, does the engine breathe? Am I missing something?
@subetherbass avatar
Lift the seat, there is a hole at the front.
Also, pull the fuel tank out, if someone missed out putting back the plastic thingee in the bottom of the void it will also be getting air from under/behind the horn
@garncarz avatar
@garncarz avatar
Yep. There is a hole under the seat! My thingee is properly installed. Thanks.
[ Time: 0.0084s ][ Queries: 3 (0.0017s) ][ live ][ 313 ][ ThingOne ]
