Piaggio mp3 500
Piaggio mp3 500
turn signal mounts have broken> How to repair them? All four are hanging down!
2016 MP3 500 Sport
2016 MP3 500 Sport
Are you sure they are broken? Sometimes, the nut that holds them on comes loose and falls off.
2015 MP3 500 ie Business
IF they are truly broken, then the only solution is to get new ones.
@garthhh avatar
@garthhh avatar
Buy new turnsignals, in the mean time
Cut a small piece of garden hose, slit long ways, slip over broken turnsignal stalk, secure with hose clamps, tire wraps or black tape
I've never seen one actually break. Come apart, needing re-assembly, yes, often.
Piaggio mp3 500
Piaggio mp3 500
I do not know how to attach a photo or I would! all four rubber mounts have broken!
Actually damaged and split apart or just unattached?
Piaggio mp3 500
Piaggio mp3 500
Split apart and dangling!
@stickyfrog avatar
Moderatus Rana
MP3 250 and 2 MP3 500s
Moderatus Rana
@stickyfrog avatar
That happened to mine from sitting out in the Florida sun for a few years. The rubber crumbled. I don't remember the brand but I found suitable replacements at a local Yamaha shop. I think I had to do a little modification though.
Piaggio mp3 500
Piaggio mp3 500
what is the process to replace them on the bike?
Remove the nut and washer on the inside of the fairing.
Beware: You will need a very skinny wrench (17mm IIRC) which can be gotten at bicycle shops.
If you are using aftermarket replacement units, be sure to solder the connectors of the broken lights onto the new ones and use heatshrink tubing to keep the connections from getting green death (corrossion)
Piaggio mp3 500
Piaggio mp3 500
tail light problem
Piaggio mp3 500
Piaggio mp3 500
All 4 turn signals! Facepalm emoticon Facepalm emoticon
Needs 4 new signals. Perfect time to upgrade to Piaggio's Euro spec LED blinkers and relay.
100% plug and play, and no more water ingress into the bulb housing or bulbs to deal with.
@stickyfrog avatar
Moderatus Rana
Moderatus Rana
@stickyfrog avatar
tail light problem
Yep that is what mine looked like. Replaced all four with leds.
mp3 500 2018 (USA-version)
I would try to rebuild the direction indicators. For example, using hot melt glue. Of course, if the new ones are not very expensive, it is better to buy new ones.
@stickyfrog avatar
Moderatus Rana
Moderatus Rana
@stickyfrog avatar
I thought of that when the same thing happened to mine but all of the rubber was crumbling and the cost of replacements was worth it to me instead of trying to fix.
2016 Mp3 500ie Sport
Credit to sbaert for the following information.
Information on the Euro Spec turn signal relay to enable LED signals can be found on this thread. Turn signal relay
"STAR Blinker device with Hazard Control Unit 12V part 1D002536R" which can be purchased from https://www.easyparts.nl/Blinker-Device-With-Hazard-p33684637
I installed it on my 2016 Mp3 500ie Sport NAFTA and it works fine with the existing incandescent marker bulbs but will also work on future LED upgrades.
GT 2.4
GT 2.4
The indicator stalks are pretty pricey. We have them and a set of four will set you back about $120. But you might be able to find another manufacturer that uses them. My Moto Guzzi indicators were about $45 each, and if I had ordered them when I needed them, in 2006, I might have them by now. Turns out Buell used the same indicators, they were in stock, and they were about $10 each.
6402455 is the Piaggio part number for the Left Rear, Right Front, and the other one is 6402455.
[ Time: 0.0127s ][ Queries: 5 (0.0033s) ][ live ][ 313 ][ ThingOne ]
