Sun Nov 14, 2021 2:52 pm
Piaggio mp3 500
Piaggio mp3 500
Sun Nov 14, 2021 2:52 pm linkquote
MP3 500 in storage for one year! Wht di I need to do to get it up to date?
Sun Nov 14, 2021 10:39 pm
2015 MP3 500 ie Business
Sun Nov 14, 2021 10:39 pm linkquote
Drain and refill fluids, change filters, and ride it.
Mon Nov 15, 2021 12:19 pm
Piaggio mp3 500
Piaggio mp3 500
Mon Nov 15, 2021 12:19 pm linkquote
Drain the gas also?
Mon Nov 15, 2021 12:56 pm
Moderatus Rana
MP3 250 and 2 MP3 500s
Moderatus Rana
Mon Nov 15, 2021 12:56 pm linkquote
Phillip..P. Smith wrote:
Drain the gas also?
Did you put stabil in when you put it in storage? If not it may start but I just got a 500 that sat for 5 years give or take and it started on the first try. If it doesn't start then you'll have to replace with fresh.
I'd do an oil change because it may have moisture and it is cheap and easy.
If you've done a coolant change in the last few years it is probably fine. Drain a little into a shot glass and if it looks like the original color and there is no sludge or rust then it should be fine.
Brake fluid I would only change if it is dark or cloudy or if the brakes feel spongy.
YMMV
Mon Nov 15, 2021 2:34 pm
Piaggio mp3 500
Piaggio mp3 500
Mon Nov 15, 2021 2:34 pm linkquote
Will do! Thanks!
  DoubleGood Vespa Design
[ Time: 0.0269s ][ Queries: 5 (0.0079s) ][ Debug on ][ 209 ][ Thing One ]
