Mon Nov 15, 2021 12:35 pm
1959 Allstate w PX Engine
Mon Nov 15, 2021 12:35 pm linkquote
Hey guys,
Still trying to make the best of my Polini box on 8's. Moved the center stand enough...
Bike scrapes the asphalt when my wife rides with me, even more so now that we've both put on the Covid 19 lbs
Tried a shock spacer, but the carb box cover hits the chassis with it on.
Any other ideas? A shock with an adjustable preload? Need 390mm here on the Allstate.
Mon Nov 15, 2021 1:58 pm
Mon Nov 15, 2021 1:58 pm linkquote
Nup... except the sledgehammer!
I've tried spacer at top of shock. Ohh, to fix carb cover hitting frame, sledgehammer also works a treat.
Adjustable shock on high setting helps
I gave away my BGM Bigbox.
Scariest time is going around a tight corner and hitting a dip in road... scooter momentarily STOPS completely!
Mon Nov 15, 2021 2:26 pm
63 Lambretta LI 125 series 3, 71 Sprint Veloce , 2005 Vespa PX150, 1979 P200E
Mon Nov 15, 2021 2:26 pm linkquote
If it makes you feel better my sito plus scraps the hell out of the belly on my sprint and that is just with your truly (210lbs) but with my son in the back the clearance is like 4". ai was going to go with Polini box.
How is your rear shock? how is the tire pressure, the two combined can have a detrimental effect.
Mon Nov 15, 2021 2:32 pm
2007 Stella 225
2007 Stella 225
Mon Nov 15, 2021 2:32 pm linkquote
Stiffer spring or progressive spring.
Mon Nov 15, 2021 3:33 pm
Lucky
Lucky
Mon Nov 15, 2021 3:33 pm linkquote
Once you've grounded it out enough times, it'll be dented enough the problem solves itself.
I.e.
Mon Nov 15, 2021 4:16 pm
Mon Nov 15, 2021 4:16 pm linkquote
I never did really figure out this problem when I was riding my old Super. I even cut it too close one time hung it up momentarily on the concrete curb, that was an eye opener. And I weigh 160.
Mon Nov 15, 2021 5:18 pm
'74 50s x3 '78 P200 E '84 Cosa '91 PK50XL2 '58 AllState '68 Sprint '80 50special and a '66(?) Super125
Mon Nov 15, 2021 5:18 pm linkquote
What part of the muff is hitting and how is your clearance between the top of it and bottom of your floor? I had the same problem with a SIP Road and had to do some muff surgery to fix.
Can you post a pic of muff and where airbox hits frame?
There's gotta be a way if you have a welder and a big hammer !
before
mostly shortened and changed the angle of the header pipe.
plus this to raise the other side to the max.
after, I was able to keep my centerstand, maybe not with your fatter box.
Mon Nov 15, 2021 5:54 pm
Mon Nov 15, 2021 5:54 pm linkquote
This happened to me many moons ago, with a Sitoplus; at a rally in LA. Right hand turn merging into traffic, 2 up; muffler catches on a bump of asphalt - immediatly screech to a stop, both of us go flying over handlebars into the street with traffic and my vespa almost got ran over after spinning round 450 degrees into the middle of the street. Thankfully not much damage to person or scoot. Tossed it up on some random persons lawn, borrowed a big hammer and bashed in the pipe; which got bent back and pushed into the tire preventing it spinning. Started right up and rejoin the rally! good times.
Mon Nov 15, 2021 6:09 pm
'15 GTS300, '86 PX125EFL, '66 VBB, '04 Ninja 250
Mon Nov 15, 2021 6:09 pm linkquote
So which box pipe is best for the 8" bikes? Do you have to go with the tiny stock pipe in order to guarantee clearance?? I'd like something better than that for my VBB but it m not hearing reassurance here. Sounds like suspension is key here…
Mon Nov 15, 2021 6:30 pm
Mon Nov 15, 2021 6:30 pm linkquote
Got those!
And what looks like some room to play with on that pipe (see pic). What did you do to the "catch nut" on the other side of that new bolt hole?
Took a pic of my friend on the bike this afternoon.
Mon Nov 15, 2021 6:47 pm
Mon Nov 15, 2021 6:47 pm linkquote
Looking for one.
Mon Nov 15, 2021 6:49 pm
Mon Nov 15, 2021 6:49 pm linkquote
Motor is, or I should say was a two port, so bolt just threads into swingarm... you'll figure something out I'm sure .
Here's more detail:
I cut at it the weld so after deburring I can put the smaller stub back inside the cut off header pipe like it was before.
bolted into the bike and tack welded in place w/ about a quarter inch lap inside
you can see the slight angle from tipping the front of the header up almost tight to the spring
the piece I cut out is hanging on the spring loop
continuous weld all around, but a little at a time so I wouldn't blow thru
ground smooth, all painted and looks good inside - job done
the washers in the clamp gap prevent the tip collapsing & force it to clamp tight
Mon Nov 15, 2021 8:30 pm
Lucky
Lucky
Mon Nov 15, 2021 8:30 pm linkquote
A SIP Road is the best option for an 8" bike that I've found. I ran that without issues on the center stand with my VBB.
I was able to run a SIP Road XL on my VBB without much scraping, but had to change to a side stand to clear the resonator portion of the exhaust.
I ran a JL leftie tuned pipe, too, and it was fine once I'd bashed a flat spot onto the bottom of it.
Tue Nov 16, 2021 9:34 am
Tue Nov 16, 2021 9:34 am linkquote
Ray - from your pic - looks like the exhaust is pointed down when you are sitting on it.
Stiffer spring will help - but also may harshen ride a bit.
There is a coupling nut on the top of the shock I believe - that acts as a spacer.
A longer one - or some lengthening of that - so that when you sit on the scoot - the exhaust is parallel with the ground - would have a significant effect in both angle and heigh of the ex. I would think.
-CM
Tue Nov 16, 2021 9:51 am
bodgemaster
bodgemaster
Tue Nov 16, 2021 9:51 am linkquote
Stiffer rear suspension definitely helps, along with having the correct size extender on the rear shock.
I have a BGM BIg Box on one Super, and a SIP Road 2 on the other. There's slightly more clearance with the SIP. I've scraped both in hard steep twisties, but after a while you learn the angles and the limits. In everyday riding, scraping isn't a major issue with either.
BGM Big Box clearance, 8" wheels
Tue Nov 16, 2021 12:51 pm
Tue Nov 16, 2021 12:51 pm linkquote
-CM
It does! Looks like a disaster waiting to happen there.
I've got a Road 2 on a shelf. As much as I love the Polini, it looks like I'm not going to be able make it work with a passenger.
Tried the spacer nut. As I mentioned, it made the carb box cover bump up against the chassis. Kinda counter-intuitive, but it is a VNA/VNB with a PX engine.
Tue Nov 16, 2021 1:05 pm
Tue Nov 16, 2021 1:05 pm linkquote
Took another look. Looks like I have maybe 3/4" clearance between the floor and the box. Not much.
I'll try a stiffer/adjustable spring and a Road 2. More surgery if needed.
Tue Nov 16, 2021 1:49 pm
2007 Stella 225
2007 Stella 225
Tue Nov 16, 2021 1:49 pm linkquote
If you can find a progressive spring that would be better. Softer ride while not compressed and stiffens when compressed. I had a motorcycle I went to progressive rear shocks so I could lower the rear to flat foot it. Wonder if you can get a rear Stoffi spring from this company?
Replace VBB Front Fork Spring with Stoffi Spring?
Fri Nov 19, 2021 5:59 pm
Fri Nov 19, 2021 5:59 pm linkquote
Got an adjustable shock. Very happy.
https://www.sip-scootershop.com/en/product/shock-absorber-carbone-sport-rear_71017000?cr=e993ab67-6807-4109-bbed-f6374ebf9f9b&gclid=CjwKCAiAs92MBhAXEiwAXTi2507JJbgj-Cby3NpJyDm91Ww8WSvgU5Dn5bmnyJ5tpJo77_a6BSvQ8BoC1JsQAvD_BwE
Bought it from ScooterSpeed in LA. Can't find a link to it there now.
No more scraping!
But now the pipe is hitting the center stand pretty hard. New shock and spacer/distance nut increased total length by 13mm, enough to tilt the pipe up against the center stand stops.
Two issues with a box exhaust on 8's. Scraping, and the center stand. Both can be solved.
Working on the latter now. Going to move the center stand forward. More on that later.
Thanks a lot for your help, guys!
New shock with 48mm spacer
Wife on board
Going do imitate this, to include the side stand I already have.
Back to the drawing board. Literally
Fri Nov 19, 2021 6:13 pm
Lucky
Lucky
Fri Nov 19, 2021 6:13 pm linkquote
Assuming that plate works, be sure to share the template!
Fri Nov 19, 2021 6:30 pm
Fri Nov 19, 2021 6:30 pm linkquote
If you're not trying to integrate the (kinda lame, compared to SoCal Guy's version) side stand I have you don't need a template:
https://www.sip-scootershop.com/en/product/main-stand-offset-mrp_22159634?cr=e993ab67-6807-4109-bbed-f6374ebf9f9b&gclid=CjwKCAiAs92MBhAXEiwAXTi250l1MBYYAJAh9QMJ0rXAKgnAJEWzhLjKBlGLxkf3fIRUBZfjIeLd6xoCRmMQAvD_BwE
Sat Nov 20, 2021 5:28 pm
Sat Nov 20, 2021 5:28 pm linkquote
Couldn't find a progressive rear shock for a Vespa! The only one that came up in a "progressive" search was the Bitubo.
Sat Nov 20, 2021 6:31 pm
Sat Nov 20, 2021 6:31 pm linkquote
Made some nice progress today.
Still some issues but looking very good
First mockup
Ready to dry fit
Dry fit
Side stand added
Thu Dec 02, 2021 6:20 pm
Thu Dec 02, 2021 6:20 pm linkquote
Okay, been road testing this enough to say it works. I was worried it would rattle against the floor, maybe make it unstable with the center stand more foreword. None of those. Actually feels more stable on the stand. Side stand seems a little more stable too, though I wouldn't recommend that one over SoCal Guy's version that connects via the engine bolt.
I do like how everything goes together out of the frame. Spring connects off the frame
It does slam pretty hard against the floor when raised. I'll probably move the spring clip a little foreword before cleaning it up for the powder coater, and maybe add some rubber under the floor later.
I think it's better/easier to just buy the plate I mentioned above from SIP. It's made out of stainless and a simple bolt-on project.
But if you have the time, a basic welder and a drill, this how to do it.
Shopping list:
1) 2 of 1/8 × 1/2 × 9 1/2" flat bar
2) 1 of 1/8 × 1 1/4 × 9 1/2" flat bar
3) 2 of 1/8 × 4 × 9 1/2" plate
4) Something to make a clip for the spring.
Once you tack things up together you can mark the holes for the center stand with it in place, upside-down. Mark the holes to connect it to the bike by holding it up against the floor and marking the holes with a Sharpie or something. I made 3/8" holes to provide some play when bolting it to the bike.
Holes were made on my machine. Better to fit the plate under the floor and mark the holes with a Sharpie.
Arrange plates like this and tack it up big-time before welding. Otherwise the thin metal will bend and twist.
Add the clip
Thu Dec 02, 2021 7:32 pm
Thu Dec 02, 2021 7:32 pm linkquote
$45 on SIP if you want to save the time.
The side stand bolt holes were even crazier
Thu Dec 02, 2021 8:07 pm
Lucky
Lucky
Thu Dec 02, 2021 8:07 pm linkquote
Seems like a simple enough project and I'm the guy who's looking for things to weld
Thanks for posting that up!
Thu Dec 02, 2021 8:19 pm
79 P200E (Ruby), 62 Allstate (B-62), 2008 Stella (Olive)
Thu Dec 02, 2021 8:19 pm linkquote
Thanks for this Ray8. I love the side stand I have on the P200 and will probably get one like SoCalGuys at some point.
I'm gonna finish up what I'm working on first, then get back to the 62 Allstate....
Thu Dec 02, 2021 9:44 pm
Thu Dec 02, 2021 9:44 pm linkquote
BTW those notches on the sides were to make space for my floor rail nuts. If you guys did it right with rivets you could do without those notches. On the other hand, they could leave room for future repairs.
With both the stiffer and adjustable spring, and making space for the pipe, I'm able to keep the great Polini box.
Took a long tour with my wife to our local pub the night before last, speed bumps (lots around here) and all.
Very happy. Thanks all for your suggestions, guys!
  DoubleGood Vespa Design
[ Time: 0.0341s ][ Queries: 7 (0.0110s) ][ Debug on ][ 209 ][ Thing One ]
