Wed, 17 Nov 2021 22:42:38 +0000
gilera fuoco 500ie
gilera fuoco 500ie
Wed, 17 Nov 2021 22:42:38 +0000 quote
Hi seemed to be some scraping noise coming from rear wheel. I thought it was just brake pads need changing but checked wheel and seems excessive movement. Guessing needs new bearing fitted?
Thu, 18 Nov 2021 04:22:35 +0000
Aprilia Mojito 125
Aprilia Mojito 125
Thu, 18 Nov 2021 04:22:35 +0000 quote
I follow one rule: if you suspect a bearing, change it. In case of rear wheel it is a bit worse because I'd change both bearings, the right one at the exhaust bracket and the left one at the reduction unit.
Thu, 18 Nov 2021 15:32:13 +0000
gilera fuoco 500ie
gilera fuoco 500ie
Thu, 18 Nov 2021 15:32:13 +0000 quote
Straight forward job? Have changed wheels bearings on proper bike before
Thu, 18 Nov 2021 16:17:51 +0000
Moderatus Rana
MP3 250 and 2 MP3 500s
Moderatus Rana
Thu, 18 Nov 2021 16:17:51 +0000 quote
You might want to check all of the swing arm nuts and bolts and the axle nut first.
Sat, 20 Nov 2021 14:21:42 +0000
gilera fuoco 500ie
gilera fuoco 500ie
Sat, 20 Nov 2021 14:21:42 +0000 quote
All sorted..right bearing was knackered..just as well as looks more difficult to get to other one
Sat, 20 Nov 2021 15:35:48 +0000
Aprilia Mojito 125
Aprilia Mojito 125
Sat, 20 Nov 2021 15:35:48 +0000 quote
Well, the left one works in gear oil. So it should last much longer than the right one
  DoubleGood Design
[ Time: 0.0281s ][ Queries: 4 (0.0074s) ][ Debug on ][ 286 ][ Thing Two ]
