@trenchleton avatar
GTS 300 Super Sport (Verde Speranza)
@trenchleton avatar
Sick of the hard start in the morning and the constant dance of the engine light - the evap system's gotta go. I know it's been detailed other places, and I'm like 85% sure, but I trend towards anxiety and am hoping someone could confirm this for me.
EDIT: In the interest of forum etiquette, I should note that I've gone over the places in the forum where it's detailed several times, but none of the photos are quite like mine.
@touring300 avatar
@touring300 avatar
Perhaps a wiki post should be created for this mod. I notice there's one for the LX150, but I haven't seen one for the GTS.
@stickyfrog avatar
Moderatus Rana
MP3 250 and 2 MP3 500s
Moderatus Rana
@stickyfrog avatar
Not sure which hose is which in your picture but I think you have it right. The hose that goes to the intake manifold it the one you plug. If you are not sure start the scooter and put your finger over the end of the hose. The one to the intake manifold will have suction.
Don't forget to remove the rollover valve on the hose that goes to the gas tank.
@pegasus_prime avatar
2021 Vespa GTS 300 Super HPE
Confirm that is the stuff to do, would remove the cannister by the two bolts as well
+ wash that engine well lol
⚠️ Last edited by Pegasus Prime on UTC; edited 1 time
@spirovision avatar
GTS super 300
@spirovision avatar
GTS super 300
Thank you !!
@trenchleton avatar
@trenchleton avatar
Yeah, I knew someone was gonna read me for that lol
@trenchleton avatar
@trenchleton avatar
If I replace the hose coming from the filler neck, won't that be cutting out the rollover as well? It's all bolted under that left cowl, innit?
Have about 3k on the HPE after removal and routing the lines, best decision I made was to pull that out and trash it
Also, once you take off the black piece on top of the fuel tank and pull out the canister, very clear what lines are attached so no worries there on which to cut, cap and re-route
Yes it's attached under that left side and you'll see it when you pull out the canister - I don't think it's worth keeping in my opinion, but I guess you could detach and reconnect to the overflow tube
@trenchleton avatar
@trenchleton avatar
I plan to detach the hose well ahead of it, just wanted to make sure there wasn't a piece to the puzzle I hadn't seen yet. Honestly I intend to just leave the junk there unconnected - faster and more convenient.
@stickyfrog avatar
Moderatus Rana
Moderatus Rana
@stickyfrog avatar
Yeah shouldn't be a problem. I only physically removed mine because it was easy to get to on an MP3. If it wasn't I wouldn't have bothered.
@trenchleton avatar
@trenchleton avatar
Well, folks, it's done. Thanks for input from everyone.
Took it on the freeway for a minute at WOT and around the block. Not necessarily extra pep but no troubles either. Wish me luck that the contemptible CEL remains off this time.
New overflow drain
New overflow drain
Nice and ziptight
Nice and ziptight
Tape to avoid scratches from the clamps
Now with capping bolt
Lookin' good #godihopethatwastherighthose
Prognosis? Did the removal / Mod fix the issue you were having on the light popping on?
@dooglas avatar
@dooglas avatar
Yes, my question as well. In the end, did it really make much difference?
@trenchleton avatar
@trenchleton avatar
To be honest, I'm not sure if it's solved it yet! I had the P0505 code pop up one more time, but I very shortly after had to park it until the snow and ice is cleared.
[ Time: 0.0171s ][ Queries: 4 (0.0075s) ][ live ][ 313 ][ ThingOne ]
